trevhutch1
Help please ! 2002 3.4L . I changed them out one at a time , so numbering is correct. Just looking for some advice. Thanks
just double check the coil - wire order, quick and easy.
also make sure the boots are fully seated on the plugs and coils.
clean the coil bolts and standoffs. I could be wrong on this but i thought the ground for the coils are the 10mm bolts that bolt them to the valve cover
intermotor ignition coil x2
spark plugs - Autolite Iridium XP Spark Plug
Part #XP5224
Exact Fit for your 2002 Toyota 4Runner
Didn't gap plugs as they were supposed to be pre gapped at .044
I don't trust afteramarket coils. OEM is about $30 on ebay. What was wrong with your OEM coils?
https://www.ebay.com/itm/9091902212...ash=item282d133bde:g:xDgAAOSwhlZYte6b&vxp=mtr
Intermotor ignition coil part # E679People are going to tell you Denso only on the coils and your plugs should be the double electrode type......but, I'm not sure that is the cause of your issues. I confirmed your plug part number on Rockauto....what's the Intermotor part number on the coil? Can't seem to find one on Rockauto or Amazon.
Buckaroo
The plugs that came out were not dual electrode and it had been running great until last Friday and it starting running really rough . Error coded P0303 and P0304People are going to tell you Denso only on the coils and your plugs should be the double electrode type......but, I'm not sure that is the cause of your issues. I confirmed your plug part number on Rockauto....what's the Intermotor part number on the coil? Can't seem to find one on Rockauto or Amazon.
Buckaroo
Confirmed the part number on Advance Auto Parts and Intermotor web sites....so, it should work....check your installation closely.
Buckaroo
