Replacing Front Seats
My seats are killing my back too in SoCal traffic. I tilt my seat back to not hit the headliner.
Were your 4runner seats manual or power to begin with? (My guess is manual since SR5)
I just bought the same seat this morning as a test too. My 4R seat is manual. I saw someone on youtube wire similar seats to manual seat car so I was game to try it.
Are your seats higher or lower than 4R seats?
I'm looking at lowering overall seat for more headroom since my head hits the headliner. I might need a welder to make a custom bracket for me.
Are make any progress on your seats?
Sorry its been a while since I came on. I bought a 5th gen last summer prior to moving. My 3rd gen is at my parents house in NJ.
The bmw 3series seats had their own wiring harness. I hooked them up directly to the fuse box and grounded inside the car. I tested with a portable battery jumper when I picked up the seats. They are full power, heated and have a lumbar controller. Heated was an ordeal to get it to work. I used bmw heat switches and had to test different combinations and look through schematics to get it to work properly.
They are higher than stock. I cut the mounting feet off the old rails and bolted then to 1/4” cold rolled steel bars to make my own adapters to fit the bmw sliders. It worked and is solid but it raised the seat. I’m 5’ 8” so it wasnt terrible. My brother is 6’ 1” and he has a hard time in there. Bmw seats are also firmer so you dont sink in. Id say there is at least a 2” sitting difference. I probably should have just found another 3rd gen and bought its passenger seat to take the bottom foam and done wet okole covers and called it a day. Leatherique doesn’t hold up well. Looked and felt great after proper application but my experience is not a good one.
I’d like some replacment or re-cover front seats suggestions. I prefer to stay with OEM; the comfort or lack there of is not an issue. I’ve searched online for months and can’t seem to find any OEM seats. Are recover the only options other than the “covers” sold on eBay? My foam is shot.
I may go with a diff seat (from another vehicle) but it’d have to look great, be electric and affordable (couple hundred) without having to do major mods.
Thanks in advance.
‘99 Limited, tan interior
Go to a local upholsterer and get a quote. Ive read a bunch of posts here in the past it cost a few hundred for new foam and new covers. Using any new seats will require a hefty investment of either time or money. Sometimes both. Mostly every aftermarket seat will be fully manual and you’ll need seat adapters to be able to install it to the stock mount points in the 4runner.
Sorry, been a long time coming for photos. I didn't take very many and the car is halfway across the world at this point. I left it at my parents house in NJ. I now live in Hawaii and have a 5th gen here.
This is what it looked like when I bought the seats. They came out of an e46 sedan and were dovetail grey. Paid $100 for both and $20 for an extra wiring harnesses and bmw switches for the seat heaters. Got them all to function but I had to look up the part numbers and schematics, then figure out a way to tap into our own fuse box.
While I had the stock seats apart, I also took the seat sensor out of the passenger side foam and placed it under the leather, over the foam of the BMW 3-series seats. It worked perfectly so that if anyone sat in the seat, seatbelt light would go off and once they clipped in, it went off. I did this for safety and to help ensure the passenger airbag would still deploy.
I bought the black kit from leatherique, filled the cracks with their products and redyed them to black. It looked amazing after it was first complete, but it has not held up as well as others have said it would. You can google it and see countless other forums. I had my hopes up because someone dyed their e46 bmw m3 seats red and theirs stayed that way for years. I only had them in the car a few months before I purchased my 5th gen. They were decent but started chipping. The dye is similar to plastidip when it's dry. It is more of a paint coat than a dye that seeps in and stains the leather FYI. Had I really known this, I would have paid the extra $100-200 for wet okole covers for these seats than buy the leatherique kit.
I sold the skins on my old seats and bought tan leather rear seat skins from the forum. I dyed those black also so I would have a full leather interior. I also purchased a leather skin for the center console and dyed that black also. It was already black but I wanted it all to be the same tone of black.
I didn't take photos, but I cut apart the old seat rails on the stock seats. I had to drill the tack welded spots on the mounting feet and rail to get the feet off. This took several hours just to take them off. I did one seat at a time so I could be sure I could still drive the car. I did the passenger first to get a better idea of how long it would take before I did the driver side install. I used 1/4" cold rolled steel bars I purchased online to the exact size I wanted. No local shops had this available. I had gone to several metal fabricators and shops and they all told me they couldn't give me a real estimate since they had no idea how long it would take but rate of $150/hr so I did everything myself. I've installed tons of head units, had just a few weeks earlier done a TRS projector retrofit so I was pretty confident I could do it. In the end, it worked out but my wife hated I was spending so much time on this car. The project took several weeks because of drying and waiting for the correct pieces to make the brackets. Once I had everything, the actual installation after I had the seats prepped took a weekend. Sat for the passenger, sun for the driver seat.
I was going to suggest against the E46 seats unless they're from a car with the sport package, but I guess it's too late for that. From my experience, the non-sport seats are flat, almost zero bolster, and not comfortable at all. The seats in my e90 with the Sport package were super comfortable, and I've been in e46's with the sport package, and they are too. Hopefully you got them from a Sport package car. Then again, I love my OEM 4Runner seats. My Mk3 GLS cloth seats- now THOSE are painful. My IS300 seats were OK, but still got sore after an hour or so. Although not super bolstered, my IS250 seats are super nice, and long trips are painless. My R32 seats are comfy too, but are more of a race seat, and are very high bolstered.
I owned a 740 before the 4runner and those seats were the best. I wanted the sport seats from a e46 for the extendable leg support and the side bolsters (biggest size sats that would fit in the 3rd gen). These non-sport ones actually were fine in the 4runner. That and I had someone local to buy them from for pretty damn cheap incase this frankenstein job didn't work out. These ones had the optional power lumbar, which is what I really wanted. Overall, they were much better than my beat up 3rd gen driver seat. My passenger seat was pretty mint though. My brother owned this 3rd gen and I took it off him when he bought his new car.
saw a thread the other day that e90 seats are 95% bolt in, just minor tweaks to the seat rail and one of the mounts. I've been searching cl for a cheap set to try out
