Replacing headlight bulbs in a '15?? How to do?
lmturne1
Anyone replace the bulbs in a 15'? The projector has me perplexed as to where the bulb is as I can't find a standard plug for the low beam bulb. High beam is a piece of cake but have no idea how to access the low beam bulb. Any and all help would be appreciated.
My goal is to install 6000K HID's for high/low, and a 6000K LED fog.
unscrew the grey plastic cap on the inside of the headlight. Inside will be an electrical connection. unplug it and pull out the bulb. It's as simple as that.
Um, [MENTION=5653]admin[/MENTION] ?
This has been implemented. All new members must have 15 replies before they can start new threads.
Thanks to mods for keepin the spammers away as much as they can! Hopefully this measure will help. We're keeping an eye on it.
Cheers,
admin.
EDIT: Ah, maybe this only became effective 8/16? So, if a member has joined before 8/16, but still has <15 posts, he can still start a thread?
25 would have been a better number. It's not hard for someone to come in and make 15 replies. On Jeepforum we had it set for 25 replies before you could start your own thread and for your BB code to be enabled for photos and attachments.
Also, I hope you have more brains than money if you're going to install HIDs in the high beam spot. The constant striking to ignite the capsule will burn it out as you flip back and forth between Low and hi
Yes, that is correct, before the patch, everyone was moved to a usergroup that can start new threads.
Thanks for the help [MENTION=126173]SKP-4R[/MENTION], and I received you message with the revised email for the icon lift. He really helped me out. I'll be posting a build thread as soon as I receive the rest of my parts in.
Sorry if I am still green compared to the rest of the guys here. I have read the rules and regs thread as soon as I joined but was not keen to the +/- 15 replies before starting a new thread. This will be my last thread before my build thread.
Cheers,
Logan
or you could post 15 times in 1 thread with a count down to the magic post number, like someone did already.
