Replacing LCD screen and temperature control bulbs
Xetabur
I’m about to replace the bulbs in the LCD screen and temperature control bulbs. Do I need to disconnect the battery before I do that? Thanks
You wouldn’t need to disconnect the battery to change out the bulbs. But remember that if you unplug the passenger airbag sensor do NOT turn the ignition on until you plug it back in. It’ll send a code to the ECU that can only be removed by the dealer and it’s expensive. My advise, just keep it plugged in during the bulb replacement.
AndiGarage
