Vehicle:
2008 Toyota 4Runner Limited JBL, no nav.
Background:
My T4R didn't comes with factory nav, I've installed an E7007 w/amber ring before but in the end went back to stock JBL to wait and save up for aftermarket head unit w/nav. Because I don't have factory nav, I don't have the BT phone and voice command switches in the steering wheel (right side pad). This will walk through the install of the switches. Note: installing the switch does not make BT work in itself, it also doesn't enable voice command by itself. In the future, I plan to maps these buttons to an aftermarket nav unit with PAC.
Procedures: (warning: do at your own risk)
1. Remove the negative battery cable from battery
2. Get inside car, starting point looks like this:
3. Next remove these covers on the side of the steering wheel:
4. Remove them by gently prying on the side of the cover closest to you. This is what it looks like removed:
5. Now remove the T30 Torx screw which hold the airbag in. (one per side)
6. Now move the airbag out of the way:
7. Now remove the right side blank pad by removing the single phillips screw.
8. Now take your right hand control switch bank:
9. Put the ribbon cable connector into the back and put the "ears" of the cable holder into their respective plastic fingers:
10. Now connect the ribbon connector on the left bank.
11. Now mount your right side bank with the phillips screw you removed off the blank plate:
12. Reverse the order to put everything back.
13. When you are done it will look like this:
14. Turn your lights on and tests that the right bank lights up amber.
15. Have a beer.
Background:
15. Have a beer.
