Ride_Red 2000 Limited Build Thread
7th Mod:
Plasti Dip the rims
This by far was the coolest and cheapest mod I have done! However, I would not recomend doing this in the dark and in the cold! I used 3 cans and put 4 coats, but should have done 5. I noticed some very small spots that I missed that I probably wouldn't have if it wasn't dark. The best thing about this, is if I don't like it. I can just peel it off!
Stock color
C701A3FD-47BA-4E94-AF53-FE88EA0F3031-3667-0000042E7E17803C.jpg~original
Used 3 decks of cards
F6E533C8-27C0-441A-B0E4-CA42C0643F7F-3667-0000042EA3EF6883.jpg~original
69CA382F-BA93-4BEC-AD72-528B917BFB4D-3667-0000042EBD0A78F3.jpg~original
1st coat
9D7B9483-DDFE-4658-A6AE-B5B62D692966-3667-0000042ED232996E.jpg~original
Becasue it was soo cold I had to let them dry over night
1F4EA095-DF26-44E9-93BD-80E51CE5A216-3667-0000042EFD50EE55.jpg~original
6CE11FB0-7F4D-4143-89E7-D9A40481F02F-3667-0000042EE7172E92.jpg~original
Like how the red calipers stand out!
B67ED0D7-DE66-4CC6-B72E-91336A8B4CEE-3667-0000042F4D98265F.jpg~original
Didn't do or put the center caps on. I kind of like them w/o them?
F0850CB7-CF80-4C52-8B42-777BF37C3CF8-3667-0000042F6C267B11.jpg~original
B6D319FF-4C99-44F8-B100-0B6737021AAD-3667-0000042F34893AAF.jpg~original
I did not do the center caps. I like how the blue wheel spacers accent the rim. Only thing I need to do, is paint or cover the rear drum, it's a little rusty.
8th mod:
Deck plate
Went to West Marine and picked up a 4" deck plate white with a clear lid. The deck plate cost me $12.00.
0C8F34BF-1FBD-46BB-98B9-540DFA3CD908-1489-000001A0877BE412.jpg~original
Took the entires intake to make it easier to work on also cleaned maf and throttle body.
9C47F5A4-221C-4EFF-8090-29F6EB59874F-1489-000001A07A989726.jpg~original
Started with a 2" hole saw toward the upper left corner for easier access.
549B23D4-9AC4-4FCE-ADE4-9BEFCB01BF16-1489-000001A09CB8B090.jpg~original
Then turned to my rotary tool.
DA5CBC0A-34E3-438D-857C-B390E90553F0-1489-000001A0AC95AA0C.jpg~original
Let the silicone dry.
B44704D5-09D2-4D78-98BB-6E5E29D3349A-1489-000001A0C6929775.jpg~original
With the clear lid.
5E25EAF8-7F84-4B55-9B8D-009B832E97C2-1489-000001A0BCC1950B.jpg~original
F427BAC8-0F0E-433F-A0D7-122548C21E2F-1489-000001A0D15E58FA.jpg~original
very nice rig man very clean! i plasti dipped my rims too and i painted my rear drums so without center caps all four match and look really good so i recommend that definitely
Painting the drums is coming up on the list. Not sure if I'm going with the red caliper paint or just black? I might also try putting the center caps back on, but I need to dip them 1st.
Do you have factory foglights housings? or the Hella MicroDE's? I thought that HIDs only fit in the microde's ?
I guess I was pretty good this year! I got some pretty cool stuff from Santa!
~Yakima Loadwarrior
~Taillight guards
~Bull bar
~Ramps
~30ft recovery strap (that I needed to use this weekend)
~GNU snowboard
~Cloths
~And some other pretty cool stuff I'll need to keep on the DL.....
E087C464-5F42-4D75-99C4-C379D56DDFEF-3559-0000030C95B3BA2D.jpg~original
63669373-655A-442A-91B9-AAF727D4B0B2-3559-0000030CAC9FCA4B.jpg~original
7F20C6A1-C8C5-4DD1-B98D-452F725CB439-4253-0000037349EE2860.jpg~original
651A8C2B-1D99-4F7D-B060-315B9025F529-3572-0000030E7986E69C.jpg~original
Lookin good! If you took off the front spacers, would it still be possible to run those 285's do you think? Thats what I'd like to do, but I don't really want spacers......
With the same rims, no. I had the rims and tires on before the spacer and it rubbed the UCA and the pinch welds pretty good. I'm sure if you get some after market UCA's and did some serious trimming/pounding, then I guess you could, but that's some work.
With different rims and better back spacing, I'm sure you could probably get away w/o running the spacers, but I'm not 100% sure?
Third maintenance:
Timing belt
Water pump
Alternator belt
And the 2 other belts I can't remember.
Flushed radiator fluid
Spark plugs
Spark plug wires
PVC Valve
Finally got around to getting all of this done w/over 140k on the clock. These were all the original parts that were replaced for the first time. Used all OEM Toyota parts where ever possible.
698ADAD2-B77D-4DF2-B6D5-3EEBE042CFA3-3398-00000392CDCC335C_zpsd8e237d0.jpg~original
CFA5DD2F-7348-42BB-A8F4-81BE215A79A8-3398-00000392FAB98157_zps6ee8be86.jpg~original
