Running Boards cost to order and Bull Guards ?s
Has anyone tried to put Toyota running boards on a Trail model?
I am being told that the SE Toyota running boards won't work because they interfere with the mudflaps on the Trail...
For the people that have installed the SE running boards: Did you have to jack the truck up in order to install the boards?
Thanks! Does the truck sit high enough that you do not need to lift it up?
It sits high enough when you remove the factory bolts and ratchet in the brackets. It got a little tight once you place the running board on the brackets and go underneath to ratchet them in. If you're not obese or have a chest like Arnold, you'll be fine
is this considered a bull guard or brush guard or push bar? this is what i'd like to get in powdercoat black for my mag gray sr5
brush guard, bull guards are just the two middle bars
I want one two, just the bull guard, I have looked around the front of the sr5 and dont see anywhere obvious to mount a bolt on one, so I guess some cutting is needed, I will look more into it when it warms up.
Glad to see all the success with the running boards
Running boards came in today. I went out and bought a socket set and I think I am good to go. I am not handy by any means and am a little nervous about putting these bad boys on. Can someone ensure me again that they are easy to put on :driving:
Thanks for the moral support!
Running boards came in today. I went out and bout a socket set and I think I am good to go. I am not handy by any means and am a little nervous about putting these bad boys on. Can someone ensure me again that they are easy to put on :driving:
its easy to put on.
good luck :D
You are right, thats why the holes are there on my TE......not being used unlike the SR5 & limited. I was not a big fan of the lower rocker panels on those models as much anyway. It takes away from the high sitting offroad look in my opinion. Are you removing the fender flares as well or just the lower rocker panels?
So is it safe to say that, to do this mod (add SE tube steps), you have to remove the rocker panels?
I'm not a big fan of them, anyway (and the dreaded chrome strip which they hold).
Would this imply that any aftermarket tube step that would fit a 4th gen 4Runner would also fit an SR5, using the rocker panel brackets?
good news folks!
looks like shrockworks has started working on the 5th gen!
heres their new rock sliders
Toyota 4Runner Rock Sliders - 5th Generation, Rock Rails 5th Gen, Nerf Bars
cheers
Would these fit on a stock SR5? I know the trail has different 'mouldings' on the sides, would I have to remove mine or do you think they will create 2 different versions? Most of my offroading is sand based, however these things look like they would be able to double as step assists in/out and possibly provide protection from door dings in parking lots.
well those are right in my price range... haha
and who was the idiot that said the after market will take two years to respond?:rockthrow:
Reading the eariler thread, (Late December/Early Jan), it would seem the T4R did not come with Running boards. Obviously, no mention of it on the Web site or any written material I read prior to my purchace. Mine did. It was installed by Southeast Toyota prior to the dealer taking delivery! Picked it up last week (Jan 29th), with the Running boards already on it. Guess they started reading this Forum!
no clue mate,
probably best to shoot shrockworks an email and ask.
Not really (with any noticeable effect). So far, running boards have been an available option in the SE USA only. In other areas of the country, running boards are not (yet) an option. Toyota USA won't even acknowledge that they are available in the e-mail I received fro them. However, it hasn't taken any time for the SE dealers to discover this and take advantage of e-bay.
Congrats on your new T4R!
Yes you would have to remove the rocker panels. Easy to take off the SR5/Limited rocker panels ,however the TE parts to replace them becomes really involved and expensive to make them tie in right..You need ALL the lower parts from a TE including the black underdoor mouldings,wheel flares and mudflaps.I'll shoot you some pics of mine when they come in as I have them on order
See above answer about changing the rocker panels of the SR5/Limited to the TE moulding.Alot of work and money.
The first sliders from Shrockworks are made to fit the TE's as that is what he had to work with to design and fit them. He needs to design some for the SR5's and Limited WITH the rocker panels on.It is beyond most peoples ability and price range to convert over to the Trail Edition and probably won't happen much at all.I'm going to call him and explain that this afternoon.He was thinking the same thing, just remove the rocker panels and everything would be good.He needs a SR5/Limited in the Houston area to work with.
Yes , they are really nice and serve to protect the truck and as a step to get in. See the pics on Shrockworks.com.
Look at the slider pics of the 4th Gen. or FJ to get a better look at them.
I believe it was harper who said... "Unless there are pictures it didnt happen" :)
:lol: C'mon ScottyTsR5
Everybody loves pics of mods. Anybody that doesn't know how to post pics on a forum ,this link is how I do it with photobucket and it's free. Note, you don't have to resize your pics to 800 x 600 if you are using a free account(they do it for you now) and with this forum you copy and paste the HTML Code not the IMG to put a pic in your post.
How to with photobucket... http://www.stevesnovasite.com/forums/showthread.php?t=27716
I would think another option is to create some sturdy spacers that, along with some longer bolts, could be used to drop the 4th gen tubular boards below the level of the SR5/Limited rocker panels. This is the direction that I'm leaning toward right now. It would really be nice if the aftermarket (or Toyota for that matter) can develop some steps that parallel the lower rocker panels of the SR5 and Limited models but on an even plain (so the steps don't sit so low).
EnviroHokie
