RustRunner build thread (fuelled by Canadian pesos)
Volumetrik
Hey there,
My name is Max, I live in Montréal, Canada. I'm studying in mechanical engineering but I am by no means experienced with cars. I read stuff on forums and I just shia labeouf it. I appologize in advance if I make mistakes, english is my second language.
Adventure begins, went and bought a 99 SR5 5MT for 1900 canadian pesos ($1385 US).
MJ7OQprS4qTKsen5pagOvvnO-WU3Foein2a-5xRW9Mokcp3gV_Xuf7nTU9KeUKO7bqUDyczwrRIe=w1323-h979-no
3GNplwngtZjcwHlgJZ1V7JP983NuGG1uwYRquDJvNf5pKTI1MHQZOAR19OxPym8yqDBAB8iBJL1v=w1323-h979-no
Right off the bat, there is a couple of issues.
1: P0171 code
2: Hesitation
3: Stinks of old doge
4: Rear gate latch does not lock
5: Rear wiper is RIP
I got a bluetooth adapter and scanned the CEL and got p0171, common code. I went ahead and did this nice laundry list of stuff :
MAF and TB cleanup (MAF twice to get rid of hesitation)
Seafoam
BG44k
PCV valve and grommet change
New plugs and wires
Fuel filter
Re-wire negative battery terminal
Fluid change for rear diff, transfer case and transmission
New upstream 02 sensor
Got used gate locking mechanism from ebay and installed
First adventure : 02 sensor from hell.
Now, there is a reason why this thread is called RustRunner, you will see why right now.
8Kl9wGGYvKc00u09lOBUhl-z8jGdjV1xfFxxtbuR3fsCd52Q78XoQeznUA0mDa9z-ecK-8E_EnJQ=w1323-h979-no
oh ye bby
O-c4fJa10UnBXQDq6MyrmjA3RZ4Dd3SsM4bWHyHX8lU4I1K3cVrLg0f3NGFbnf6ZzuokWgrFcqn2=w1323-h979-no
studs had to shear off on me
N8WTwY2kGJ3-5yKQdBvC8p0KV5OFN41LFIwK7h1ZKwjRviudycWwNL1M0bjvPO0nRbSmL7KyHS7s=w1323-h979-no
old 02 and dead studs
kyeCi_RX5nhem9O9-L1-rQaBd7JEWDL0raTcIJYY-dZTTm7swSnVVnJjfcjFV5FlSgFtV9sXojNK=w1323-h979-no
the only logical thing to do
0Vd7SQDWyj1CP4g57pK-Py0ND2WUYtzGnnHhZZLNY0uKGVPugpifv5rtOOsUYQQJw_co2lRs8Nvl=w1323-h979-no
stole some kubota exhaust studs from my dad
hSi9ZG9wBJpz0mpfRyy-cvsDBx8iaOtHJQ4Z4GtGcShhCc_zEQcbI926FOepo5qdAUwclbKcnd0B=w1323-h979-no
making moves
3JxQRTIMoRF24pUp6vKMyXHBj4DhcOlxtFxU7zPk5TIJ6NLOhbL6H5hBYm7YIsDdzNUefA5tXBMc=w1323-h979-no
digged out this sweet tap set
nBJdmH6TY8k7J6hOZB4gvVV9EDFr4z8MeM2NQsasD4nSuRKUnLa4S663kaEmqrb_JqPVPA0SPHbZ=w1323-h979-no
you already know
ccXlmB0QrqfeVHBOgZuM1Td3pZqLehTCTclxgCk0xnRVvQbblBg6GgNPoBE9BQjX0NM5Ii8llZRf=w1323-h979-no
cleaned up and ready for gasket
h0ot-1YY45Axth7BkAILO1yuzLWwS__l1Bifs8ojq0AAhQozBjd8D4OpV4WmdqC0OuQJmUfazUna=w1323-h979-no
gasket on
gk_dPhX8GMF8a3gDZqS5bFM3h7FwVwNtg4ZhK_OCcGO3yDYisos9uZxaPXjP3NWrTg5RvN18plgN=w1323-h979-no
everything bolted on
mKzS9_9oUpCdp4wSiv1I03nSfFUf9o6DnDHLDHverVouVmSnSJbnAp1OLRmib2rVOD6ea41KKd6C=w1323-h979-no
Pretty happy about the result, I was very lucky to find two studs and nuts around the basement for this to work. It took me longer to shear of the two nuts on the sensor and remove the mid-pipe than to drill, tap and install the new 02 sensor.
Here is the album of the pictures for the 02 sensor job if you are interested:
02 Sensor change
The next adventure will be even better !
AYasT3dXFj4cKmwhfQS40mv59BUYpV1I4D3mSm5Qp4GI3nz6OCyOe1txHjtZ_Wvto-cEbNgR1L-i=w725-h979-no
Join me next time when I will struggle from 1pm to 5am to drill-out and re-tap TWO exhaust studs.
Second adventure : Y-pipe studs
Continuing where we left off, I started drilling the first stud out.
legtWFzySKUH5T5L7k02N6C66iWRp6E5U9D6o67qcyjUPrtAIPVnPaBfy07mY2LWaW8TYIXCxlk2=w991-h1339-no
Got all the way through. This took about an hour believe it or not.
EzetK1utGzm1YpJJkV4VxvHZqU-dAqAwU9hDntkwOw4AOjPtPq0tdNkvNF-b4eUCNu5-xSKZJcZk=w991-h1339-no
Tapping
NFMiLrSoW3cAW3E85qawcCPyy5SBItdzw8bfszeFdAodLQiUq0uQaF_Oi5D7yG-ZqTCKwBNdyST5=w991-h1339-no
Here is the hardware I used. The studs are OEM toyota studs picked from the dealer.
8sjyWJw2DfiuoRYY8ISRv_6buLEze-IQQhVQKxz7ZdgqMN5SHGvvQpVXFJCe3TY__fLgnsiDOaob=w991-h1339-no
First stud installed
rqIfoqM35CgirAQ3H-DJVvO8uEcxw1TNaq9xpqe4nYCzgSVITvp2NFZXPfSoorbNMrjkTeOS6zxI=w991-h1339-no
I had to make a cutom drill bit attachement to reach into the space to drill the last stud out
gs5mtnvOswhRKrvYO88eNEfx7nYVE-uITCVfCsghxtZYCijXExqvX91BRWblEFDYOZTFggha0Yvz=w991-h1339-no
I didin't take any pictures of the actual process of drilling because my hands were to dirty, but it took 2 hours alone.
Here is a picture of the tap in the flange
sK2ebAQkk6nFf575qdUQcod61Dj1UkytghaJ11m0ppC8oZFHBqHB-Z978oPK5zvLx8CNzDiodX0w=w1810-h1339-no
I had to use unorthodox methods to drive the tap correctly in with the non-existent space I had.
Z4zqgdJ6NF4-DDnJXYjQO6TB4meMEocJLgjWM9qC-gfjP5pdu-vzI5zGGSHr6x47V021GpcC1lte=w1810-h1339-no
And these are the exhaust gaskets installed on the mid-pipe.
173szxI0HQyGCzu9PqmwwnKO9C9QQASQD00GK9S7lhBcYk-NJ0Fv_LBkE8-FeUQK6Bdwldei9inO=w1810-h1339-no
Everything is installed and good now. This took me from 1pm to 5am, so 16hrs of torture.
Here is the picure album for the whole process
Y-pipe stud replacement
DJNutshell
