alexb
Simple question. Is it safe to use the Gobi roof rack as a ground point for things like LED lights? I did a bit of searching but didn't find a definitive answer.
I found this post here by [MENTION=65614]Antman[/MENTION] http://www.toyota-4runner.org/843765-post4.html
So I guess that is a pretty definitive answer, but just wanted to double check.
Good news is you only need to run the hot lead into the truck. The ground can be terminated at the rack; Where the ground wires exit at the back of the rack, terminate those with a ring terminal, and place the ring terminal under the bolt head for the rear "GOBI" bracket where it bolts to the roof. I put a stainless star washer between the bolt head and the stainless washer from GOBI to get a solid ground. Tighten the bolt and cover it all with liquid electrical tape, and you are good! Hope this makes sense- I really need to do that writeup...![]()
