Saker’s Midnight Build
June 21, 2016
DDM TUNING SABER LED HIGH BEAMS 6000K
3000lm per side of LED Joy!
(see link for all photos)
http://www.toyota-4runner.org/2393282-post44.html
April 06, 2018
I just upgraded to these DDM Tuning Saber LED, 9005 LED Bulbs, 50W, 10000 Lumens / pair!
In it’s natural habitat....
How do like the lights ? Blind on coming traffic? High low beams work? Paint the roof rails , it’ll give it a nice look
I don’t understand exactly what you’re asking or if you’re being sarcastic!
If you rephrase, I’ll answer.
April 2, 2016
Installed Plug and Play Rear Camera Override Dongle
Wiring diagram
198554d1459663841-plug-play-rear-camera-override-dongle-camera-dongle-switch-diagram.png
Thanks Saker! I have searched for hours for this information on how to wire the AOB switches so that they will dim. Glad i finally found it! Did not want o just use a fuse tap and not allow the backlight to dim at all.
Hopefully, Toyota did not change the wiring color scheme from your 2014 to my 2018 ORP! Wondering if anyone knows that answer? Might use a voltmeter to check it to be safe. I assume the Wiper Warmer switch gray ground is a varying voltage ground that actually causes the LED to dim. Do you know how to find it with a voltmeter if it's a different color?
Glad this was able to help you.
You could more than likely use a test light and see if it dims on the same color....
Hope this helps!
The wiring color scheme is the same for 2018. Worked fine except the T-Taps were a bit flakey and it was a tight fit. The Air On Board switches fit nicely but the LED backlighting is not uniform from switch to switch.....minor detail.
Hey man, nice meeting you in Trader Joe's the other day. Great looking rig. We were the Cement TRD Pro folks
Very nice meeting you as well. thx for the kudos.
Saw you posted in the spotted section!:thumb3:
I was referenced to this build thread by another member's post who said you'd found some high-quality MOLLE backed seat covers. I'd be curious to know what brand you went with?
Thanks in advance for the time and help.
Nope, not me...
:peace:
5th Gen Marker Grill Lights
I’ve been looking at doing this mod for a while.
Decided to take the plunge and see if I liked it or not.
Bought the following items:
Smoked marker lights, relay, AOB DRL switch and required 2 amp fuses, connectors and wire. VHT smoke lens paint to paint 2 coats on the already smoked lights to give them a more stealth look even when lit.
I think they came out really good.
They are totally black when not on and not overly bright when lit.
Night shot inserted.
Hey T4R friends, I have to say my TRD Skid plate my have saved my life if not saving me from being broken up pretty bad. Got me up and over an obstruction across the roadway on the way to work last Saturday morning.
All curtain bags deployed, knee bag and steering wheel bag.
Oil leak on passenger side, front tires contacted inner wheel wells, can’t open front passenger door and Lord knows what else...
Waiting on feedback from insurance company!
DionicioLives
