keithsnell
Took my 2010 Trail in for an oil change today at 30K miles. Since the dealer had replaced the engine air filter and cabin filter at 25K, and almost all the other 30K maintenance items were "inspection" type items, I specifically asked for just an oil change and lube the propeller shaft. (Much less expensive than just specifying the 30K maintenance.)
I made sure the service advisor put "lube propeller shaft" on the ticket, even though he said "we lube all zerk fittings with each oil change." I was surprised when the maintenance was done and the ticket said "Propeller shaft lube N/A." When I asked why it wasn't done the service advisor said the tech marked it N/A because the propeller shaft was "sealed" and there were no Zerk fittings. I said "are you sure? The owner's manual specifically calls for lubing the propeller shaft at 30K?" He said "Sometimes the owner's manuals have errors because they just "cut and paste" from one manual to the next."
I drove the vehicle home, crawled underneath with a flashlight and confirmed that 1) the vehicle actually did have zerk fittings on the propeller shaft (specifically on the slip yolk and spiders), and that 2) they obviously hadn't been touched due to the presence of a light coating of mud on the fittings. I drove the vehicle back to the dealer, showed the service advisor pictures of the zerk fittings and the page from the service manual showing the location of the fittings. To give him credit, he sent the vehicle back to the express lube shop and they had a "training session" with "all the guys" to show them where the zerk fittings were. And the Service Advisor comped the price of the oil change and lube. The scary thing is this is a 2010, and I got the distinct impression that they really did believe that the drive shaft on the 4runner was "sealed" and didn't require lubing. Have they been skipping the lube on all the 4runners that came through their shop since 2010??
I've had many other similar experiences with this same dealer, so much so that I almost didn't buy a Toyota when it came time to replace my '96 4runner. The last time I took my 2010 in for an oil change, the ticket said they had used conventional oil instead of synthetic. The service advisor said, "no problem" and went out the the vehicle and replaced the sticker on the windshield with one that said they used 0-20 synthetic. Problem fixed!??
I'd love to find a qualified independent mechanic in the Wichita area if anyone can suggest a mechanic they trust.
