Re: extra antenna plug
did u by any chance take pics? i wanna see
whitney8 said:Just installed my SCION single disc unit. Very happy with whole process and results. It seems that with more Scions appearing in the road, the prices on ebay are coming down.I got my for $86 including shipping. Very happy with my first ebay purchase.
Anyway back to the install.
I have read about taping up the extra antenna wire. However, I was curious so I started looking at the back end of the unit. I found that the SCION head unit DOES HAVE A SECOND ANTENNA SOCKET for the smaller antenna wire! However, it is covered up.
I removed the thick metal heat sink, and one half of the sheet metal cover. The smaller jack is right next to the main antenna jack. (Remove the screws with the little arrows next to them.) I measured the location of the second jack and drilled holes in the sheet metal, and the thick cast aluminum heat sink. Reassembled, and installed.
I can attest that the reception is better than my original 4R unit.
WARNING - Do not drill holes with out removing the parts being drilled. You DO NOT want little metal chips in your Head Unit!
Thanks Everyone,
Whitney
