Sensibility of using a "Toyotas Techstream" CD/Adapter kit from Chinese eBay sellers
38vn38fa
Given the price difference between the two, and the fact that the seller's in question (I won't link to specific auctions) have good feedback, their product is very tempting (35$ vs. 1400$). Can anyone give advise as to whether or not this is secure (from a not-mucking-up-your-vehicle standpoint), and what the repercussions might be if something were damaged as a result of using the Chinese knock-off?
Further, can anyone say if what these people are selling is a pirated copy, or a legitimate copy, or...? What precisely is it that they're selling? My understanding of techstream is that it is a "subscription service", but the eBay sellers mentioned above seem to be offering it on a CD.
To restate the question: Is there a consensus among people who have used this software (from the eBay sellers), and does using it pose a security issue for a vehicle such that damage may result?
EDIT: To just add a bit to this: techstream would cost you the price of an adapter (400-500$) plus 55$ for two day access, if you chose to do a two day access. I take that to mean you'd have to pay the 55$ again every time you decided to use it again, after that two day window expired.
LOTS of people here are using the Chinese cables and pirated Techstream, me included.
The software is without a doubt pirated. Mine at least, is also use count limited without being able to "check-in" online. I can easily rationalize the piracy for the outrageous cost of legitimate licensing - I am not making money with Techstream, which is what they are obviously licensing it for.
What I do, is simply use a WinXPx86 Virtual Machine to run the software, with a snapshot just after install. That way I get around the use limit and don't have to worry about "extras." I would have to do it that way anyway, because there are no available x64 drivers.
Install could be a biatch since the included instructions are usually worthless. And there's no tech support for Chinese pirated software. Your best form of tech support will be this (and other Toyota) forums. Most of the info is already in previous threads so I won't get into detail. But the basic gist is you'll need an older PC WinXP x86 or as mentioned earlier, Win 7 w/ virtual x86. Search and patience is your friend.
I use the Chinese version - it works great.
It's hard to screw up your truck when Toyota locks the PCM down so hard that you can't even change a tire size in the EEPROM, let alone settings that actually affect how the truck runs.
What hacked knock off Techstream???? :lalala:
I just bought it for the OBDII cable and made sure it worked with the test cd and threw it away. It did work as advertised and it's a good cable.:lol:
I think I deleted the test software but memory isn't what it used to be. :confused:
I know nothing!
I may even have a copy in my Google Drive account if you wanted to give installation a shot before purchasing your own "unofficial" copy.
I used mine in august to program the "dealer" programmable options and set the lighting timers. there is a long thread about this and some guy did put a working copy up for download. the software is difficult to get started with, I was just about to give up when mine started working, I set everthing I wanted and havent had a problem since.
I ordered a cable off Amazon and was able to DL 7.20.041 off TPB. I installed it on my x86 desktop with no issues so far.
So what did you use for the Key or are you just running it in Evaluation mode?
Does that let you do everything or does is it have limited functions?
search Download music, movies, games, software! The Pirate Bay - The galaxy's most resilient BitTorrent site for techstream
DL
Install instructions and key's are included in in the .txt file.
I am still waiting on the cable to use on the T4R. But I can open and navigate the program. 3000 days till my subscription is up.
That's pretty dangerous since those torrent sites are loaded with viruses and malware. Just going to that site brings up a bunch of Pop-Unders!
I've got a copy of the program but there was no txt file and no key generator.
I Dl'd the file today with no issues, use at your own risk i guess. You will have to find a key specific to your version.
