Sequoia/Tundra Axle for LT
MrSeth
Member
I saw this question was PARTIALLY answered in another post, but not the question that I have.
Yes, the Sekillya shafts are the longer length I need for the LT I am fabbing and the end cups are the wrong spline size/count to be plug and play... BUT can one remove the C clips on the inner shaft, remove the 3-bearing rollers, and swap them over to the longer inner shaft effectively lengthening the whole assembly?
Basically, are the splines that Im pointing to the same diameter/count on the 4R AND Sequoia shafts?
TIA guys
lilianmarais
