Shoots Build Thread.
With out having been told to?
As for your wiring diagram. At first glance I thought it was some oem or online diagram. You should see the scribbles I jot down once something gets too numerous/complicated to remember off the top of my head.
yeah without being told to.
ok sweet. i plan on start building a new wire harness and add a few hundred $ in lights up top on the roof
Where did you mount them?
Man... gona make me plug my phone in, import/upload pics. ....and now I should probably up date my build.
lol :p :wink2:
You remember that aluminum block off plate I made?
Could easily fit 2 more but I spaced them like that for quick recognition.
lol :p :wink2:
yeah i cant mount mine there because of my touch screen double din. u think i can fit 6 smaller switches in the garage door opener door?
how was wiring everything?
whats going to suck is working around the head liner for these wires.
just get a 3d printer and do what banditrunner did.
could you put a panel in where the ash tray is? you don't have a cb there do you?
I think you could easily fit 6 switches in the top sunglasses/garage door opener compartment. As for working around the head liner.... Its not that bad with us having the rear hatch to open and shimmy the thing out.
I'll be running my wires through one of the roof rack grommets at the back of the roof.
But if she backed it in, what will you hook up your hammock to?
BAM. Reason to buy a rear bumper. :lmao:
Thanks guys.
Yeah rear bumper is in the process in a few years.
Jburt. I havnt seen the 3d printer where he put it but I have used one in my cad class.
No cb there.
So it sounds like the head liner is easy enough. Never done it. Think I'll have to run with the truck apart for a few days so I can get all this wiring done.
Bandit's switch panel is on this page. I think it turned out pretty good.
http://www.toyota-4runner.org/3rd-gen-t4rs/70298-bandit-runners-build-thread-13.html
I'm envious of your sunglass holder. I wouldn't mess that up. But it would probably be easier.
PICT1933_zpsdc465d17.jpg~original
Oh man, Driving around with out the head liner sucks. Last time I was in a vehicle with no head liner my head was splitting from the drone. Mind you it also had no back seat or carpet and the exhaust was loud, might not be as bad in the 4runner. You also have to pull every piece of trim off to pull the liner, this includes at least partially removing the front seat belts.
I would first get the switches set up in the cubby. Figure out where your wires are running, power/grounds and any thing that requires the liner out. Set aside a long day or weekend, enough time to at least get the liner back in and a few clips/trim panels to hold it.
Got some updates today.
Last night I started tearing the truck apart. Broke a Phillips bit on my impact drill in order to get my OH S**T handles off. When it broke it stripped the bolt so I had to drill the head off in order to get the handle off then I plan on grabbing it with vice grips. That blue lock tight was globed on those bolts.
Not to mention those 6 push in clips in the trunk area absolutely SUCK!
I plan on rocking the truck like this for a few days until I get all my wiring finished. Then I'll install the lights and everything else. YAY!
What are you planning on running for lights once you're all wired up?
still my KC driving long range spots with 100W bulbs up front
4 4X4 light pods on the roof in between the roof rails. (2 on each side pointing in each direction to use for side light.
45" bar upfront by the wind shield (waiting for more money)
then im not quite sure what i want to go with for reverse lights. im thinking about attaching some type of bracket to the rear wing and mount the lights back there somewhere.
Nice! I know there are a couple of places that sell flush mount LED's, so maybe look into those for your reverse lights in the wing?
Truck looks good though. Love the shot of the hammock tied to the bumper.
White wires on relays were pulled off to not be used.
Yellow and 1 red wire (supposed to be black) go up to switches. For a signal and jumper power relay.
Black wires are fused relays pos. red are relay grounds.
Blue wires go up to the lights then I will ground them all on the roof. (Maybe. What's your input on keeping that ground connection clean and dry from corrosion?
chasebradshaw
