Shrockworks Sliders with KDSS enabled T4R question
el_kab0ng
I've been kicking around the idea of getting a set of Shrockworks sliders for my '16 TE w/KDSS, but from what I've read with other sliders on KDSS enabled systems, it's not as simple as just bolting them on without having to make some adjustments.
For those of you who have a set of these on a KDSS enabled T4R, can you explain (and maybe even show some picts of) the adjustments you had to make before bolting them on?
Not shrockworks but Metaltech bolt right on. All that is done with kdss is you unbolt two bolts that hold the lines on, slide the plates behind the lines and bolt the sliders on through the line brackets and done. You don't remove skids, kdss pump, nothing. Very simple and straight forward.
I know it's not what you asked but an alternative choice that is simple.
This was still extremely helpful as I'm pretty confident the SW model would follow a similar install process.
Thanks!
I have shrockworks sliders... no modifications, and they bolt right on exactly the same way as the metaltech ones mentioned earlier. Those damn sticknuts are interesting though, hahaha.
There are no modifications needed to install the Shrockworks sliders. They bolt on using all factory holes (2 optional holes can be drilled into the cross member) the plates that are welded on to the slider will fit behind all kdss plumbing after loosening some hardware. It is a super easy install.
BillM777
