Side Marker Lights
Yazoo 4Runner
My 99 limited has side marker light problems. They will not turn on or blink while setting the alarm. Is there a fuse specifically for these lights or are the bulbs blown from blinking so much while setting the alarm? All the other lights work, i.e. (headlights, fog lights, tail lights, and blinkers) Any help would be greatly appreciated.
I would check your relays... i do not believe there is a specific fuse but that would be easy to find. In the same fuse box there are a couple of relays, which look like a small box. Whenever i set my locks i can hear the relay which regulates the power that gets to the lights. Put your head beside the fuse box and lock/unlock it if you don't hear it clicking then it should be a relay problem.
Talyn
