Side mirror lights! Post them here!
Why the spots over floods or wides, or even driving ones?
I'm actually using the d2 spots on my truck right now as well. I'm trying to find a configuration that works best for me and I wanted to see if my spots would throw the light further then my driving d2s and they do. The spots put the light just in front of the fenders off the sides and the driving fills the area from the side mirror to the end of the fender.
Sent from my SM-G930V using Tapatalk
I'm surprised, shouldn't the spots cover less surface than the driving or flood ones?
Cover less area yes, but they also have a further throw so with the position of my ditch brackets the flood lights cover the area hidden by my side mirrors and hidden behind my a pillar and only a small area off the fender. The spots can actually hit further in front of the runner and out to the side to help with cornering a lot more. I've used about 4 different set ups and I still haven't found my perfect setup yet but this is just what I've learned from what I've tried.
That's really interesting! What flood lights were you using, the Rigid D2s? I guess my question is are you comparing flood, driving, and spots on the same product?
Would you be kind enough to direct me toward / post a picture of your current setup?
I've used baja's squadron and squadron pros and rigid's spot, flood, wide, and driving pods. Currently I have my rigid spots on the outside and baja squadron pros on the inside and my rigid flood pods have been re-purposed as turn signals. I also have a set of piaa 520's converted to HID as my fogs and the 42" bar above the windshield.
Forgot to mention I don't have a bumper on the front of my runner. Here's a night shot of both ditch lights and my fogs on from my security camera.
Thanks, it's a pretty intense setup as far as extra lights go! I like the double sixth lights, I was thinking about it yesterday, by pairing floods and spots or hyperspots.
Which brackets do you use to mount two lights on each side? The Rago?
Yeah that was the reason I got the double was to pair different lenses to get the most coverage I could. The ditch mounts themselves are the cbi ones and the extension is made by Rago. You can get the whole set up by Rago as well I just already had the cbi ones. I'm getting some hyper spots from that group buy you signed up for yesterday and hopefully some xl80's from the mint 300 group buy which are going to be insanely bright at 9500 lumens per pod! Can't wait to see what that setup looks like.
9500 lumens per spot! That's really impressive!
You probably went the best way with the brackets, I don't really like where the Rago ones sit but love the idea of pairing spots. Did you have to modify the CBI brackets to install the Rago extension? From what I understand no, but I can't find much info on that.
Also, according to your experience, what works best, the regular Dually or the D2? I'm trying to choose right to avoid reflection on my hood.
The difference between the dually and the d2 is only the optics in front of it. The dually uses hybrid and comes in spot or flood and the d2 uses specter and comes in driving, wide or hyper spot and both come in diffused. The extension just bolts on, I used the hardware for the lights to hold it.
Hideous idea.
To each their own.
Lockers are a better investment.
Politeness and manners would be a good investment for you to consider, that is when you're done with lockers.
No hard feelings, but come on...
I'll contact the guys at Rago for the extension piece then. Would be a useful one to get.
I need to decide between a combo of 2 floods + 2 hyper spots, or only 2 spots, like driving ones.
Driving ones seems to be a good compromise too.
I'm also looking at the D-SS line, interesting stuff but almost impossible to have feedback on them.
The squadron pros I have are the same optics essentially as the driving d2's they just put out more lumens. I'd say get the hyper spots for the inside ones to limit glare off your hood and spots or floods for the outside ones. I want those d-ss ones too! Just not sure how much light they actually throw off the sides, would probably be a lot less then what I have considering I have an entire pod dedicated to side light.
That extension would be extremely simple to make as pictured.
I am seriously considering a set of the Rigid D-Side shooters, one set of lights would be better than two of them per side IMO.
For those that have 'Ditch Lights' How often do you actually use them?
My ditch lights are always on. I adjust them for off road use but the way they are now they light up the road very well and help see things more clearly. They won't distract a driver beside me unless that driver is literally on my side mirror.
Another thing to consider about those side shooters is from what I gather the lights on the side are pointed directly out and not directed towards the ground at all so I'm not sure if they are going to illuminate anything off the fender like ditch lights should they may just help widen the lit area the main pod is hitting. Not sure if I made sense there or not...
That is something to consider, the Side shooters may be better in a bumper mounted application.
chasebradshaw
