Signs you need to replace CV axle
themaestro
I'm replacing the needle bearing with the ECGS bushing. While I have everything opened up, is it worth replacing the entire drivers side CV assembly? I have 103k miles, 2010.
What would be signs of needing a new CV? It was rebooted at about 50k.
If there is a grinding or popping from the CVs while you move when you are turning, or if a boot is torn and throwing grease everywhere you might want to look at repairing or replacing it.
Otherwise, if it ain't broke...
[Edit] But if it does break... Only replace with OEM. Pretty much everything else is junk except RCV's which are $$$
^Exactly what [MENTION=129593]MTN4RNR[/MENTION] said. Also, if you do have to replace them, Most dealerships sell factory remanufactured ones at a significantly cheaper price. They are better than the ones you can source locally. The parts store versions have not fit without binding.
Jhunt
