SilverStar Question
ptung07
Hi,
I when taking out my silver star bulb I accidently touched the bulb. I have not put the bulb back in yet because I know it shortens the life of the bulb. (because of fingerprints, etc) Should I use 91% isopropyl rubbing alcohol to clean the bulb before using it?
Thanks, Paul
It's because of the oils on your skin, not because of your fingerprints. Like when you touch a butterflies wing, it will die, same effect.
I don't know that the % matters, just any alcohol that will take off the oils so that the bulb doesn't pop.
alcohol content doesn't really matter that much. What does matter is that you clean it fairly quickly i believe. If I remember correctly, the oil from your skin allows the halon gas to ecsape through the glass. Once it escapes, the bulb gets much hotter, as the gas keeps it cool. I think I heard from a knowledgable source, that the longer it's on there, the more "damage" done. But I may be totally wrong about that.
The oils of your skin that stick to the bulb create a hot spot on the bulb. The bulb is an explosion risk (I had one blow up in my face once, don't underestimate!) when not perfectly clean.
Thanks guys! I cleaned the bulb, however, now my front directional signal turn bulb is burnt out. haha, that was the bulb I least expected to burn out because I replaced it about 1 year ago. (after doing the DRL mod)
ALt4r said:
:awais: Myth.
Haha, no it's not. If you strip off the powder from their wing, they cannot fly. If a butterfly cannot fly, it dies. Not that this conversation is relevant to headlight bulbs lol.
Powder only uncovers their membrane. A butterfly guy did this with several butterflies, tagged them, and they were still alive a while later. With your logic, if it rained and a raindrop took some powder off its wing, the butterfly would die. I guess there aren't any butterflies in the rain forest.
Sorry for thread hijacking.
I think the bulb you cleaned should be fine, although i heard of an instance where life was shortened by touching it, even when cleaned. Either way, you never know how long yours is going to last anyway, silverstars are unpredictable.
