Skid plates underneath TE
calcrc
Hello, does anyone have some pics from under their TE. So I can compare and see if mine has them. I took a quick look but I didn't see nothing under the gearbox. Thanks
There is a little skid under the transfer case (attached to it). It won't be a flat surface front to back, there are a bunch of gaps.
There is also a full skid covering the entire gas tank on the TE vs. the partial skid of the SR5/LE.
I'll double check next time I'm underneath but I'm pretty sure my SR5 has those skid plates. In in Canada though, there might be a difference.
The stock sr5 plated are a joke, they might as well be made of tin foil .
Yeah for anything serious, they're fairly inadequate other than keeping the grime out. I noticed that you have the ARB skids...how do they compare in terms of coverage and rigidity? Also if you don't mind, how much did they set you back (bought in CDN or US)?
older pictures, as I was in a hurry when I had it up on the jack stands this past weekend, but you still get the idea...
IMG_20121116_090044.jpg~original
IMG_20121116_090051.jpg~original
