Awesome dude! Thanks for the info! I’ll be doing something similarHad the plumbing done a few weeks ago so the pumps was a quick job. I’ve got a 1 gallon seamless tank as pictured and a airline going to the rear jack storage area to a 2 port manifold which has a gage to monitor air pressure. With this setup i can run a air tool for repairs or whatever
I mounted mine under the hood. It works great. I made a bracket that attached in 3 places. I used 2 existing screw holes and added a rivnut. It was still shaking around a bit so I later added an aluminum brace that attached to the top of the compressor and it’s been solid. the air connection comes out in the passenger wheel well.
do you know what fitting/thread pitch they use for the hose that comes out of the compressor? I want to replace it with a quick disconnect but it's not the same 1/4" that you see on most compressors.
I just finished mounting my compressor tonight! I hadn't even seen this thread until now. I ordered my compressor like a week and a half ago. XDHas anyone successfully mounted a smittybilt 2781 compressor on board under your hood? Any insight would be great. If so are there any mounting brackets available? I haven’t been able to find anything on this. Thanks
That’s awesome!! Honestly I like that you got that set up to work! I eventually got the arb dual compressor with bandi Mount. But I rigged it up and went to turn it on and nothing so I have to troubleshoot that. Somehow someway. Which is really frustrating. But I would definitely love to check out your set up! Pm me dude we can hit some trails sometime tooI just finished mounting my compressor tonight! I hadn't even seen this thread until now. I ordered my compressor like a week and a half ago. XD
Anyway, I used C4 Fab's battery tray and drilled some extra holes. See attached pics. It was about $125 after tax and shipping.
Hope this helps. I'm excited to finish the electrical for an in-cab switch and the plumbing. I'll post more pictures when I'm finished!
PS: I see you're in Santa Clarita, I'm in Simi Valley, so we're practically neighbors. If we're ever in close proximity maybe you can check out my setup if you still haven't done yours.
Sent from my SM-G950U1 using Tapatalk
That is a monster !.... :wow: Maybe I was thingin' the smittybuilt 2780 would fit and not the 2781'...
Can anyone provided actual dimensions a (see sheet below)? I ask that as the net' listed 16.1", however image Dontkicktrees' posted shows it in an area that's has only 15" total clearance and it has a little room to spare even.
Thank You,
Leroy (bandI)
A =
B =
C (mount holes) =
D =
E (mount holes) =
F =
G =
H =
I =
Got my pumps in yesterday, now to tackle the wiring side of things.
When I was researching solutions on mounting my 2781 I found this thread. I used LT Ambrose 26's idea of using C4 Fabs mounting tray, but did it a little differently and wrote up a guide on how to do it since it was not clear in his post. So far it has been working very well.
I typed up a full guide on how to do this yourself.
did you add a pressure switch to let it run?
No. It is now powered by my switch pros system. I just use the compressor for the tires and don’t have a tank.
