Klevrboy
I have the same problem only I also found this stuff near my truck...
YOU KILLED FROSTY!:flamethrwoer2:
yes I do....but snow should not be building up in the engine compartment.....that's all I am saying....You do know that the engine compartment is not a sealed compartment.
I was hoping that this would be an informative post and might spark some discussion....and there have been some very helpful posts but the amount of negative passive aggressive BS posts on here are very disappointing........this is supposed to be a forum where people can come together and discuss topics openly......the current topic may not be a build issue on a front bearing but that's the point of the forum....variety.
Yea i don’t know what Toyota was thinking.
As long as it don’t end up like this...
:naughty:
took a shot of the drivers side light, there is about twice as much moisture as shown after I drive for a bit...this is after sitting over night.[MENTION=146325]Bucko[/MENTION] do the top of your headlights have rubber seal trim? Looks kind of like the trim around your door jams.
The hood is the exact same hood as the 2010 model. There has been no new design of the hood, which shows how much your techs know and why you should do a bit of research before posting stuff like this. The front end changed, not the hood.
Snow or rain, depending on a lot of factors, will get under the hood. It does not hurt anything as everything is designed to get wet under there.
:naughty:
I didn't see any gasket like the doors have but when I lift up the plastic that goes over the headlights.... where the front and back of the headlights are sealed I see spots where there is clearly some gasket sealer and other areas where there is no sealant .....that I can see at least...
I may add some after market seal like that.....I'm getting a couple of new dust covers for the back of the headlights (drilled holes in the original for the HID grommet) and I'm going to install the original Halogens and see if the moisture goes away.....if not then Toyota said they would replace the headlight assy.
My guess is you drilled a touch too big.I may add some after market seal like that.....I'm getting a couple of new dust covers for the back of the headlights (drilled holes in the original for the HID grommet) and I'm going to install the original Halogens and see if the moisture goes away.....if not then Toyota said they would replace the headlight assy.
