So Who's had To Replace Their Heater Control Valve?
Thank you very much. So if I put the blue arrow hose to where the green is, where do I put the green arrow hose? Where the blue was? And will this keep how water from flowing to heater core so that my ac cools as much as possible? If it weren't for BAD LUCK, I'd have no luck at all! Thanks
You can leave it attached to the heater core or take it off and store it for when you replace the heater control valve. You might be able to bend it back to the other heater core connection.
I think you have to have so mavy posts or activities before PM becomes active.
I pulled 2 of theses valves off at a pick and pull with my 3rd being off my parts rig.
So you have to keep an eye on it but should buy you some time until you get a new one.
It's very common for these to fail leak and break due to their age now .
This is why most users always by new ones to replace them. ;)
Sent from my SM-A505U using Tapatalk
If/when you replace the heater valve with a new one, I wouldn't buy it from Amazon unless it's an oem one. I went through 3 different cheap valves from Amazon in a little over a year, all junk and leaked within a few months.
I finally bought an OEM one from part-souq, it was way cheaper than anywhere here in the states. Since the part is small and light, even with shipping, it was still way cheaper.
I can't remember which member on here got one from Napa but he said it's been working fine for several years now if you want to go that route.
I could be wrong but I think it may have been [MENTION=99144]19963.4lsr5[/MENTION]. With the Napa heater valve. Of course I maybe wrong. :/
FWIW I was just looking for the heater control valve for my '96. It's about $75 with shipping from Partsouq but Amayama has it for about $45. If you're not in a hurry, of course.
Yes, I have a Napa on mine and it’s still good with no issues.
I’ve been ordering a lot of parts from amayama lately. It takes me a couple weeks to find time to install them so what’s a little more time waiting for them to arrive? Lol
I can understand trying to save some $$. If you do end up going with a new OEM part I usually find my part on part-souq then buy from Toyota Georgia or NC to avoid paying tax, they usually have pretty good discounts too. You can get an additional 25% off from Toyota by using promo code: GRob25Q324 Its a one time use promo code so try getting everything you need when using the code. With all the discounts your Toyota OEM part should run you about $75 which I believe qualifies you for feee shipping. Best of luck!
BillM777
