SOLD - 1986 Toyota 4runner SR5, $3300, Baltimore, Md
Status
Not open for further replies.
tofattofish
***SOLD***
Toyota 4runner 4 cylinder(22re), 5spd, 215K. Surco Safari Roof Rack(has 2 unused light tabs), 4 Hella Offroad lights, Wet Okole seat covers(fronts only), ZUK Mod, Manual Warn Hubs, upgraded headlights to removable bulb style, trailer hitch and wired for trailer lights, half doors that are 75% finished. Bedliner on front and rear bumpers. Have a car cover for a van that I would use when the top was off, comes with it. Have the original engine compartment light that plugs in under the dashboard (appears to never have been used). Top and sunroof doesn't leak.
31x10.5x15 Tires Michelin with half tread
New in the last 10K, Clutch and Flywheel, front brake calipers, pads, rotors, spark plugs, rear window motor, trans fluid, transfer case fluid and rear differential fluid. Oil changed every 3K.
New battery 6/18/13
Interior is in great condition.
Typical Toyota Rust, but not as bad as most. Small rust hole behind the license plate that was repaired with steel stix. Windshield is cracked in lower drivers corner. Hood was replaced. Passenger fender was replaced and replacement fender didn't have antenna hole. Antenna wire is there in the fender, but no antenna is installed. Still picks up some radio signals. I had satellite radio hooked up and the stereo has an AUX jack, so it didn't bother me. A/C works OK, but needs a charge. Only thing that doesn't work is the rear window defroster and I've never tried the cruise control.
This has been my daily driver for the last 2.5 years. Never let me down. I've driven it camping to Assateague, North Jersey and Western PA with no problem. I'd drive this anywhere.
$3300 obo
im very interested in your car. i tried to PM you but it did not go through. can you try to PM me please?
1986 Toyota 4runner 4 cylinder(22re), 5spd, 215K. Surco Safari Roof Rack(has 2 unused light tabs), 4 Hella Offroad lights, Wet Okole seat covers(fronts only), ZUK Mod, Manual Warn Hubs, upgraded headlights to removable bulb style, trailer hitch and wired for trailer lights, half doors that are 75% finished. Bedliner on front and rear bumpers. Have a car cover for a van that I would use when the top was off, comes with it. Have the original engine compartment light that plugs in under the dashboard (appears to never have been used). Top and sunroof doesn't leak.
New battery 6/18/13
$3300 obo
Status
erinobr2000
