SOLD 2000 toyota 4runner 4x4 Imperial Jade North Hollywood,California $5000 OBO
YOTAGUY93
Hello up for Sale is my 2000 Toyota 4runner V6 Limited 4x4 Imperial Jade with 254,XXX miles.
Vehicle has a mild 2” Bilstein lift on Ko2 Tires. Vehicle has some upgrades that I have done. All upgrades have less than 1000 miles on them. Since I’ve owned the vehicle I have driven less than 1000 miles(I’ve owned the vehicle for 2 years). I was trying to make an off road vehicle that was very capable that I can take camping with me. Unfortunately the past two years have been busy for me; I haven’t gone camping therefore I haven’t really used it. The vehicle has a clean title with NO Check Engine Light on. I just paid for the tags and smog was done as well. I have pink slip and smog certificate on hand. It’s time to move on; my loss is your gain. I’m asking for $5,000 O.B.O. Cash Only. I’m willing to negotiate price if reasonable. Please don’t waste your time or mine with a low ball offer. I’m selling vehicle AS IS NO WARRANTIES. Thank you!
All upgrades/ work done were done to improve the vehicle and as preventative maintenance. I have Receipts for everything that was put on the truck.
Lift Front- Bilstein 6112
Lift Rear – Bilstein 5100 paired with Rear Old Man Emu 2906 Medium Load Springs
Spc Upper control arms
White Line lower control arm bushing replacement.
Steering rack bushings replaced with energy suspension
All rear control arm bushings replaced with white line bushings
New OEM Toyota lower ball Joints.
New OEM outer tie rod ends.
New Denso Radiator
New Toyota Red Coolant
New Ko2 tires 265 75 16 less than 1000 miles on them.
New Brembo front brake rotors.
New Akebono front brake pads.
New Rear drums and brakes replaced.
New front and rear stainless steel brake lines.
New Ngk Spark plug wires
New OEM spark plugs (denso I believe, bought at dealer)
New OEM –Timing belt/ Water Pump service done
New OEM Belts
New OEM Fuel Filter
New PCV Valve
Started LED interior light conversion
No rust on frame
No rear locker
Cons-
Cv axles are leaking due to lift. Cvs May need to be changed.
Antenna stopped going up and down recently.
Needs Alignment
Paint on roof is burned by the sun
Bumpers have a few dents- a non-issue if you’re looking to armor your vehicle
I'm trying to upload pictures but it doesn't allow me to do so.
You can message me and I can send you pics through text as i figure this thing out...
More pics of vehicle
Hello. I'm looking for a daily driver that I can take offroad on weekends. Do you feel like this would a be a good fit or would it be better suited as a dedicated adventure rig? Since it would be a daily driver, reliability is my first concern. Thanks!
A lot of people daily the 4runner but personally I wouldn't. It's a gas guzzler and it's slow. If none of that bothers you then this fits the bill. I took it to the sequoias at different elevations no problem.
I daily a camry.
I'm coming from a '94 Trooper, so those two things are no problem. :) My commute is only 8 miles, so I can get away with low mpg for my daily. I've pretty much decided that I want a 4Runner but I guess what I'm unsure of is whether the lift and suspension mods make make this any less suitable as a vehicle I can depend on to get to work every day. I'm new to lifted vehicles, so please forgive my ignorance here.
I guess there's no way to PM you without getting to 15 posts and I don't want to spam threads just to do that. Please email me at offremovethischord at hotmail.com if you're interested. (Remove "removethis" from the email address.)
Thanks.
PM Sent
Thanks.
Cpn2mss
