mom
Banned
Solved: 3rd generation Toyota 4Runner digital clock repair DIY
SUMMARY: (MY FIRST DIY on this forum! Wish me luck and help me with the naysayers. Gory details to follow in photographs)
1997 Toyota 4-Runner clock has been dead for a decade. Removed center cluster. Removed clock. Opened clock. Removed four tiny silver springs; yanked four contact pins; soldered pins to the circuit board; threw away the old silver springs. Reassembled clock. Reassembled cluster. Voila! The digital ticker is now back in action!
Why another DIY? The main DIY in the first reference was good, but it wasn't exactly the same setup as mine; plus in the reference threads, MANY people had difficulty resoldering the pins, so I took pains to describe those steps better than the main DIY and with more detailed pictures. It's ok if this is too much detail because those who already know how don't need this DIY. But for those, like me, who are scared to move forward before knowing what they're doing, this DIY should help.
REFERENCES: (The intent was to stand on their shoulders and fill in what they left off.)
http://www.toyota-4runner.org/3rd-gen-t4rs/67508-3rd-gen-dash-clock-fix-3.html
http://www.toyota-4runner.org/3rd-gen-t4rs/28758-4runner-clock-problem.html
http://www.toyota-4runner.org/3rd-gen-t4rs/38559-clock.html
http://www.toyota-4runner.org/3rd-gen-t4rs/45709-dashboard-clock-not-working.html
http://www.toyota-4runner.org/accessories/30579-digital-clock.html
http://www.toyota-4runner.org/audio-electronics/6821-1998-4runner-limited-digital-clock.html
http://www.toyota-4runner.org/3rd-gen-t4rs/59184-what-fuse-fixes-clock.html
http://www.toyota-4runner.org/3rd-gen-t4rs/55352-help-clock-problem-my-99-limited.html
etc.
READ THE FACTORY MANUAL:
After reading the references above, open the Toyota 4Runner 1997 factory shop manual to sections BO-45 “Remove Center Cluster Finish Panel”, AC-55 “Air Conditioning Control Assembly”, & BE-157 “Clock Troubleshooting” in the Toyota 4Runner shop manual (Note: The Chilton repair manual was virtually useless for this particular repair.)
Notice the factory shop manual advises to check the dome-light fuse if the digital clock is not working. This DIY assumes your dome light fuse tested OK.
Remove the key from the ignition so as not to short anything.
Notice my Toyota 4Runner has the clock in the top-left corner of the A/C panel.
Remove the four knobs on the heating and air conditioning controls in the center cluster by pulling straight out. There is no need to remove the radio volume control knob or the air-conditioning on/off switch (ask me how I know).
Once the four knobs are off, your 4Runner center cluster will look like this.
With a thin spatula (the factory manual recommends a flat-blade screwdriver taped on the end to protect the plastic), carefully pry off the heating and air conditioning cover plate.
Notice the air-conditioning on/off button will pop out along with the heating and air conditioning cover plate as you work the tool around the edges.
Remove the heating and air conditioning cover plate with the air-conditioning on/off switch attached.
Page BO-45 of the 1997 Toyota factory shop manual shows the location of the two #2 Phillips head screws which need to be removed.
Remove the bottom right #2 Phillips head screw from the center cluster.
I started to remove the upper left #2 Phillips screw from the center cluster when I realized if it fell, it would be lost forever.
< arbitrarily cut here because of overly restrictive forum posting rules >
etc.
