Southern Style Offroad Full Length Roof Rack
Anyone know where you can get the replacement edge trim that goes on the bottom of the wind fairing? I guess mine got blown off the vehicle when my wife took the 4Runner to a touchless car wash. I've tried cntacting SSO but haven't received a reply. Thanks
anyone figure out a solution to the bar drainage issue yet? Every time I wash it, the slots on the bars fill up and slowly leak over hours causing streaks down one side. I Vacuum it out which helps, but is quite irritating. I am considering drilling holes at the end of the slots so that they drain properly.
lol yes I had this happen too. Saw it go flying away when I was driving through the drying fans. I picked it up and put it back on and applied silicone to the bottom. But yeah without it, it really rattles like crazy.
What a world we live in where people demand to be precision updated on the manufacturing of a product on a business' assembly line.
SSO does own some responsibility for people's dissatisfaction by trying to provide the ability to track your order. They could save themselves some headaches by not trying to do it at all. A lot of responsibility falls on the customer for not being an adult in control of their emotions.
Frankly, I think it's a fair thing to have open communication about your production with your customers, especially when they have paid in full up front for a product that is several months away from delivery. There's been too many boutique companies taking money and going belly-up lately.
I've never had issues with my XM with my roof rack installed.
Definitely - Mine seems to be a lot more sensitive to bridges/underpasses and other line of site issues. Places where it never cut out before the rack now have intermittent signal loss.
Note a huge deal - I love the way the rack looks and the signal usually only drops off for a second or two.
Hey there! We don't have it on the site, but if you email us at [email protected], we can manually put an order in for you. It is $10 + $6.50 shipping.
So I kind of fixed it a little better but still goes out often. I have a 2019, so I had a 3" in front of the antenna and a 2" in the rear. The 3" was touching the antenna which I think was causing some of the interference. I swapped it out for a 2" and it has a little better reception.
This is aggravating. My solution it to drive to the end of the block and back and then dry the truck. Works like a charm.
Anyone have any experience with mounting a kayak rack on their SSO? Have a preferred brand for mounting 1-2 kayaks? Thanks
Alternative for the silicone?
I traded my 4Runner in for a new one, so I'm getting set to re-install the rack on the new truck. Since it's been some time, I wondered if any of you figured out an alternative to the silicone application at the mounting posts? Call me stupid, but I'm actually having one heck of a time getting the old silicone off of the metal posts...I've tried heat, a razer blade, denatured alcohol -- what a pain the a$$. In any case, has anyone figured out a rubber washer, a soft rubber gasket of sorts, a cover or 'boot' type idea -- any protective, waterproof alternative to the silicone? I remember making a royal mess with the stuff last time because I was so paranoid about leaks. If any of you guys have a tested/proven alternative I'd be grateful for the insight.
One of the other manufacturers uses some sort of foam and pressure seal arrangement. I forget which one, but one of the newer to market. It has an open rear with no fairing so I couldn't dig the visuals despite its function. But they promote that application and as far as I know it is unique. I think they're based out of CO or thereabouts....but the name escapes me.
Sherpa Equipment Co
Sherpa uses a rubber gasket and rubber bonded washers to provide a seal without resorting to silicone or other goop. I just installed mine. It installed...right...like something the OEM would have engineered.
cremebrulady
