SP9100 switch pro melted inside the module
214RUNNER
Member
Any one have a SP9100 melt between the positive post and the large wire harness, the negative pin melted out of the module and is stuck in the wiring harness connector. I had this about 1 1/2 years with no problems, all the connections were good I OHMed all the wires & checked out good only the inside of module & the negetive pin was burnt. Also all fuses are good and checked all accessory functions with jumper wire to power checked all grounds & every thing works.
AndiGarage
