spacers and aftermarket coilovers?
coyotecody
I have a radflo setup with control arms. I believe I have it maxed out or something because get a banging when going over top side of speed bump. It is only time I notice it but sounds terrible. I am way past the suggested setting but cant go lower. I thought about getting the smallest spacer I could find and back off the coilovers to suggested setting. What would this effect? It rides rough as hell and factory ride was way better.
Sounds like you would've been better off with just a bro lift. Not much getting around the fact that the aftermarket coils are a higher spring rate.
It still has travel and enough it shouldn't effect it going over a simple speed bump because we tested it before ever putting it on street. They told me more than posted on the site now and told me the extended would get an extra 1/2 in or so. Its not so high that my cv are at a bad angle as I thought before.
Sounds like the shocks are topping out, but you said you have the Radflo shocks. How much lift do you have and how much lift is the shock listed to handle?
edcultural
