Spacers to run 4th gen sport rims
Mark_BC
Senior Member
I found a sweet deal on these 4th gen rims that I love.
But they are inset about 15mm compared to the 3rd gen rims so I will need a 1/2" spacer. I searched and can't find a straight answer on this. Does anyone know which spacers are good? Also I see that hub-centric spacers are required but then in another thread someone said I should get lug-centric spacers. Am I still able to do hard off roading with these 1/2" spacers?
Also I hear that the rear wheels are actually inset 1/2" compared to the front anyways because of axle length. Will I be able to get away withOUT spacers on the front / back / or both? Will it look funny?
I've gone through the same process not long ago.. ended up buying BORA 3/4" wheel spacers. 50$ per spacer, 200 total. Been on the truck for a few months now and no issues. I have noticed that the studs on the spacers gave me about 5ish more threads than the stock studs. [emoji106]
Have you tried fitting them on your truck yet? The least clearance to the upper control arm will be at full droop, so just lift the front and try it. You may be pleasantly surprised...
Assuming you have near-stock sized tires, at least.
-Charlie
I had to run those beautiful wheels with spacers. I cant believe more 3rd gen don't run them.
265/70/17 with 99 Talls. No rubbing.
seltzernator
