Spacers
Yeah that should work. You might wanna try to find someone whose also used it as well though. One reason why a lot of people buy daystar/cornfed is because its common and everyone knows they're good. This is kind of a mystery unless you can find someone that's tried it.
Might want to get something for the back too...because 3 inches up front is going to make you pretty front high...
Compare these to Daystar in design, they look very different. Not much meat around the bolts coming out of the shocks. The Daystar have studs that bolt directly to your shock studs and the spacer fits on top of them. The studs on these spacers are offset so you will need to turn the shock to mount them. not sure you can do that with XREAS.
I went with Daystar, $159 for front and back and they are solid.
fhgy0045
