Spark plug gaps
KidVermicious
Well-known member
I read a thread on another forum about a guy doing some basic tuning of his Ford motor. A lot of what he was doing is similar to what we do - he increased his air in, bumped his timing, and then he increased the gap on his spark plugs by a couple hundredths.
He figured that with more air and earlier spark, he wanted bigger spark to go with that. I think he's off his rocker and that's not going to do any good unless he opens up his injectors and gets a bigger ignition coil, but as long as I'm under my hood, what do you guys think?
I did a little research on this, and opening up the gap will help a little, but it also puts more strain on the other ignition components--the coil needs more voltage, the wires can fry due to increased resistance, and on down the line. There is a sweet spot for the gap, and anything beyond that does nothing to help. I did find one source that said the factory specs are typically too small for optimum burn, and you can increase .010 for better performance. So basically, a small amount can help, but too much not only doesn't help, it can lead to component failure throughout the ignition system.
I think the factory does this intentional. They want their engines to run a little rich to help the engine last a little longer and to avoid it running too lean.
If there was a gain from this, it would be very minimal... maybe a couple ponies and the gas mileage difference wouldn't even be noticeable.
I would suggest to leave it stock and reliable. If you want to modify it, do it right and get a MSD and use hotter plugs, not opening the gap on regular plugs.
Considering what these engines are being used for, ANY mods concerning spark plugs are a bit over the top--the tiny gains won't even be noticed in anything less than racing conditions. An MSD ignition module would be a better investment, which would give noticeable results for everyday use and trail running.
Gonzaga Lobos
