Spark Plug Wire's?
Unless you're building a high end motor I wouldn't waste money on something like spark plug cables. Just get the OE replacement ones from your local auto parts store. You'll never notice a difference between OE and more expensive ones.
It's a mild motor.
In general, Toyota's plug wires are top-grade items that are hard to beat. A mechanic friend of mine has actually "repaired" running problems by removing aftermarket wires and putting on old, used factory wires. I'd stick with OEM on this one.
Looks like that is what's going to end up happening.
i have seen a few toyotas come in with check engine lights on because they used aftermarket wires. run oem. they are expensive but only need to be changed out every 10 years or so
pax at 4
