Speaker and AC Issue
Gtrain
The left speaker on my 94 is busted. Are there instructions for taking that apart and what kind of speakers would I need to replace that?
The AC seems to be very dirty I believe, are there instructions for AC cleaning and does this 4runner have a cabin filter?
The air filter is new so that shouldn't be the problem for the AC.
Thanks in advance for all your help guys.
-G
are you talking about your front left or rear left speaker. front left is a little tricky because you have to remove the entire panel and work around the e-brake. not that big of a deal though.
when i replaced mine, i took the old speaker out and brought it with me to a car stereo shop. this way I could compare the depth and mounting holes with the new set i was to buy.
It's the front left speaker. I just need to know how to take the front dash apart to remove that speaker to replace it. If someone has pics or a DIY, I'd really appreciate it. Thanks.
I've got a 1990 and I think the dash should be the same.
There's about 4 screws holding that peice of the dash in and one bolt. The bolt is at the far left at the bottom. The screws are all fairly visible just shine a flashlight in all the holes to see if there's screws in them.
All you need is a philips screwdriver and a 10mm socket.
The speaker is attached to the dash peice. I think the speaker itself is a 4" speaker.
You should be able to get it apart easily enough.
I had my dash all apart last night. I didn't think to take pictures though. If you decide to do both speakers the right side is a little more tricky. A couple of the screws that hold it together are in the glove box.
MMJR_T4R
