Speed-dependent whine/buzz in cabin
t4rjasper
My 2003 V6 makes an annoying mosquito-like buzz that varies with vehicle speed. It starts at about 10 MPH and increases in pitch as vehicle speed increases. It is not a function of either engine speed or transmission gear, which makes me think it is a digital speed sensor or transducer under the dash. Anyone have a similar experience and, if so, how can I get rid of it?
No, the stereo is the factory setup and it's turned off when the noise is happening, but that's exactly the kind of noise it is.
Have you checked the seal around the windshield, the windshield wipers, and the blower vents? Sounds a bit daft but any mosquito sounding noise I've ever had in a car that gets worse with speed has just about always been due to one of those three things.
Thanks for the replies guys. I'm pretty certain the buzz is electronic but I was planning to go over the windshield seals anyway as highway trips will start happening soon. You never know, it might be something on around the glass.
This is a longshot because it doesn't necessarily fit the conditions you noticed, but I figure I'd mention it just incase:
The only other buzzing sound I've had in a 4th Gen was from the brake booster/master cylinder. It is a pretty noticeable sound. Try opening the hood, starting the engine, and getting a buddy to depress the brake peddle while the truck is in Park. You should be able to get the booster to start buzzing.
If your IPOD or IPHONE is charging via Cig lighter and hooked up to AUX, it whines, its the alternator you are hearing in your speakers.
I had this prob because I bought a $0.75 ipod charger
If it goes away with the radio off, then its something else.
After my alarm was installed, they put a new hole in the firewall and didnt seal it. I heard like a whosshing sounds that got louder with acceleration an rpms. look under your hood , on the drivers side against the engine bay and truck. theres a like a black soft plastic cap. check to see if theres any wires going in there that arent sealed around I sealed all of them ad the sound went away. gl
All good tips guys, thanks. Funny thing is, in checking all your theories I'll probably end up finding other things that need TLC. If and when I locate the source of the noise I'll let you know. I really think it's an electronic gizmo under the dash but I've been wrong before, as my wife keeps pointing out.
