Spidertrax 1.25" - Stock 2000 Suspension - 265/75/16 on stock 5 stars...
Will I rub?
Tried searching, curious who has done this and what kind of clearance there is, if any?
Cheers!
I had factory size tires on some aftermarket 16 inch wheels with stock suspension and those same spacers, and mine rubbed a little bit at the lower inside corner of the front of the flares. I know a slightly larger diameter tire would have made it worse, but depending on your alignment situation, it'll vary a little bit. I don't know any of the specs of the wheels I had, but I know they were very close to the factory size. If those 5 stars are any smaller than the ones I had, you might just barely skate by, but I would anticipate some rubbing in the flares.
Many people fit 265s on stock suspension without rubbing, i know i did but i also have a 99 so its a bit higher. Is there a reason why you want to run the spacers? i suspect the ruubing may be worse with them at stock height than without them.
patnewton
