Sputtering - no CEL no codes
DK327
Member
Hello all,
As I was coming up to a red light earlier today, I noticed the vehicle started sputtering as if it was gonna stall, so I quickly turned into an empty lot and let the vehicle idle for a bit to see what would happen and after a couple of minutes, it was back to normal. No check engine light, no codes.
As I got out of the vehicle to pop the hood, I could smell something burnt, not sure if I'd call it rotten egg smell like with a head gasket but it was definitely a burnt, foul smell. No white smoke from exhaust.
I got my phone and recorded a short video of under the vehicle as it was idling as well as the engine bay. You can't see anything abnormal expect for the sputtering sound, more pronounced under the vehicle as it's closer to the exhaust. Below is a link to the video:
https://www.youtube.com/watch?v=96dimYcOmz0
https://www.youtube.com/watch?v=2yQDUVRjDrk
If anyone has any idea on where to start troubleshooting this thing, I'd appreciate it. The fuel filter was replaced back in 2016 with 232K miles on the clock, right now I'm almost at 280K, and the gas tank's full. I'll check the throttle body and MAF sensor, both of which were also cleaned back in 2016 but if that were the cause, I think the sputtering would always be present and wouldn't just appear and disappear on its own?
Thanks in advance!
Dumb question, but does your OBDII reader show Pending Codes as well?
I have a Scangauge hooked up and it didn't detect any codes; I have another OBD2 reader that I can hook up and test again, which I haven't done yet. Will do some tests over the weekend to see if I can get it to act up again.
Hello all,
Thanks in advance!
Sounds like a similar issue to what I have on my ‘97 w/ 212k. It only happens when warmed up and started noticing at stop signs and parking.
Did you find out what it was? Coil packs?
Deka
