SRQ Fabrications Retrofit Headlights
Hey everyone, my name is Matthew and I'm the owner over at SRQ Fabrications
I normally don't venture over to the 4th gen forum but figured I'd share with you some cool retrofit options we've been working on for 4th gens. All of our projectors us high-end aftermarket housings or OEM housings. We also work exclusively with Morimoto, TRS, and Diode Dynamic products. These companies have shown they are the top dogs in the aftermarket lighting industry and we only use the best on our builds.
03-05 4runner Single Projector Retrofits: https://www.srqfabrications.com/product-page/03-05-4runner-mini-d2s-hid-retrofits Start at $700
03-05 4runner Dual Projector Retrofits: Link coming soon (currently building a new site) Start in the $1000 range
06-09 4runner Single Projector Retrofits: Link coming soon (currently building a new site) Start in the $800 range
Alittle about what we build:
Using innovative technology developed by Morimoto, a top of the line manufacture in HID kits, the SRQ Fabrications build team is able to create a product that converts a 20-year-old headlight into something that can compete with the light output of today’s top car manufactures. Combining the excellent quality of Morimoto HID kits and TYC housings with the attention to detail of the SRQ Fabrications build team we offer a product the will surely impress. Converting the stock housing to a full projector setup not only looks cool but also provides the amazing benefits of being able to run an HID kit. The Mini D2S kit by Morimoto is the top 3” projector on the market. With 4th generation Mini D2S optics powering across their curved cutoff shield and through the standard Kuria Optic clear lens, the Mini D2S 4.0 is a force to be reckoned with. Razor Sharp, unbeatable width, a perfectly distributed gradient of light down to the foreground, and a high beam that’ll put some off-road LED bars to shame. While the light output benefits are obvious, projectors also allow you to customize your headlights to make them your own. Options such as shrouds, halos, and demon eye kits will allow you to show off your show quality retrofit headlights.
Standard Parts:
High-end housings and lenses
Professionally painted using UV protected paint
Morimoto Mini D2S Stage III 4.0 Projectors
Morimoto XB D2S 5500k Bulbs
Morimoto 35w XB Ballasts
Morimoto RetroRubber Gray Headlight Sealant
MotoControl Wiring Harness
Option Information:
Switchback halo: This option means the halo only changes between amber and white. Often times connected to your turn signals and corner light so that the halo blinks amber when you are turning and remains white while you are driving straight.
Color change halo: This option comes with a remote that allows you to change the color of the halo to multiple different colors. You will be able to adjust the brightness, strobe patterns, and fading options. This option also includes an amber wire which overrides the current color when it gains power. This means that the color change halo can also flash amber with your turn signals, then go back to your color after you are done turning.
Demon eye: A small color-changing LED that is placed in the projector itself. This allows you to change the color inside the lens while the HID bulbs are off. Controlled by a Bluetooth remote.
Front halo: This halo is mounted to the front of the shroud around the front of the projector lens and can be seen when not on. Sizes of the halo vary depending on the shroud chosen.
Rear halo: This halo is mounted inside the shroud and can only be seen when on (as pictured above). It shines through openings in the shroud and provides for a clean look that is also very functional during all hours of the day. Sizes of the halo vary depending on the shroud chosen.
If you are looking for a custom setup or looking to place an order for one of the products that do not have a site link, feel free to PM or send me an email [email protected]. We also have a ton of other cool 4th gen products that can be found here on our site, including 06-09 4runner grilles! www.srqfabrications.com
Vspro9
