4Running Daily
After the frame rails were mostly straight, it was time to deal with the core support.
**** sheet metal.
Story time: I bought this 4Runner from a dude in Surprise, knowing it had a rebuilt title already. But that's fine #racetruck, what do I care. Obviously the front end was ****ed from the accident, so I didn't really look too carefully. Plus he told me it had an elocker, and when I got there it didn't. And because there was a tow truck in front of his house already, he wouldn't negotiate. So $2k came and went.
Now that I'm balls deep in this truck, I've discovered that the core support has actually already been replaced once before. So not only am I fixing one accident, I'm actually fixing 2. I'm thinking the first accident that totaled the truck is the one that bent the frame rail. It was fixed cheaply, and then given a rebuilt title before it was smashed again and I bought.
Long story short, **** this thing.
Core support rails looked like this:
Untitled by Connor Rhoades, on Flickr
New core support
Had to pull the original out in an attempt to un-**** it.
Then cut it
Start tac-ing the new one in place before test fitting for clearances
It sucked
But finally we arrived at this
And then dropped the radiator in place to check for clearances too
So everything looks ok. I can play with the fitment of things later when I get the fiberglass in. I still need to disassemble and full weld the entire thing together. Need to pick up some sheet metal to weld some of the gaps. Should be ok though. Even with my welder set on the lowest setting, I struggle to weld sheet metal haha.
We're getting there though.
**** sheet metal.
Untitled by Connor Rhoades, on FlickrNew core support
Untitled by Connor Rhoades, on FlickrHad to pull the original out in an attempt to un-**** it.
Untitled by Connor Rhoades, on FlickrThen cut it
Untitled by Connor Rhoades, on FlickrStart tac-ing the new one in place before test fitting for clearances
Untitled by Connor Rhoades, on FlickrIt sucked
Untitled by Connor Rhoades, on FlickrBut finally we arrived at this
Untitled by Connor Rhoades, on FlickrAnd then dropped the radiator in place to check for clearances too
Untitled by Connor Rhoades, on FlickrSo everything looks ok. I can play with the fitment of things later when I get the fiberglass in. I still need to disassemble and full weld the entire thing together. Need to pick up some sheet metal to weld some of the gaps. Should be ok though. Even with my welder set on the lowest setting, I struggle to weld sheet metal haha.
