OK,
Today when I pulled into my garage, I decided to goose it a little just to feel manly and hear that V8 echo off the walls. I started off gently and then really punched it so it would rev all the way up to 5000 rpm. Obviously, all this was while I was in park, so the engine wasn't under load, so it was revving quite fast. A very interesting thing happened when I was doing this: (If you haven't yet, take a look at my dyno runs above) Right at ~4250 rpm the engine was temporarily cutting out, it actually felt like I was bouncing off the rev limiter!! it didn't stop at this point it just bounced a couple times and kept going, but it was very noticible (I should also mention that some minor backfires were present on the way down from 5000 rpm). This cut in timing and/or fuel is in exact correlation with my dyno runs! I wonder if this is the same thing that was happening during my dyno pulls. I'm almost done with my 87 octane tank. Next tank will be 93 octane and I am going to do the exact same thing and see if I get the hesitation. I should note that I haven't been able to reproduce this hesitation during driving, even in 1st gear. If one of you guys feel like it, try this same thing and report if you see any hestitations like this at all...I'll report back after I try premium fuel.
