I hope I'm still wrenching when I'm 50. Good job! You guys are putting out great material.![]()
The one thing that older men have is experience!I hope I'm still wrenching when I'm 50. Good job! You guys are putting out great material.
lol -- i said that before to him and I think the comment has been said 20 times now.
If you bought the Prothane #18-1115 kit, the end link bushings won't fit well. The inside diameter of the ones in that kit are 15mm. The end link posts are 10mm wide which makes for a very sloppy fit. End link bushings from the Energy Suspension Kit #9.8105 fit correctly. That kit comes with 8 bushings and 8 washers.
[b]Toyota OEM buna:[/b] (same size for all 3rd-gen 4Runners, 2WD & 4WD)
- Toyota 10mm ID Endlink bushings (Part #90948-01003)
- Toyota 26mm ID swaybar body bushings (#48815-35100)
[b]Daystar polyurethane:[/b] daystarweb.com +1-800-595-7659 tech at daystarweb dot com
- Daystar DAY MO3464 Body Bushing ID = 1.045 inches (26.5mm)
- Daystar DAY MO2233 End Link Bushing ID = 0.395 inches (10.0mm)
[b]Energy Suspension polyurethane:[/b] energysuspension.com +1-888-913-6374 (Dave) dlewis @ energysuspension dot com
- Energy Suspension kit 8.5141{R,G}, endlink bushing ID = 9.64mm, swaybar body bushing ID ~= 26mm <=== do we have an accurate measurement yet?
- [s]Energy Suspension kit 8.5118{R,G}[/s] (Do not buy this kit as the swaybar body bushings are a too-tight fit at over 27 mm)
- Energy Suspension 9.8105 kit (containing just the endlink bushings & washers)
[b]Prothane polyurethane:[/b] prothane.com +1-888-776-8426 (Dominick) dominick at prothane dot com
- [s]Prothane kit #18-1115[/s] (Do not buy this kit as the endlink bushings are a loose fit at 15.04mm ID)
Well, now I know why you had a problem with those washers from the Energy Suspension Kit 9.8105. The diameter of the hole is only 9.8mm and the end link posts are 10mm wide. So, I gave you some bad information. I was told this kit fit well for our rigs, but maybe the person just meant the bushings and not the washers. The bushings are a good fit.
The reason why I was wondering why you had problems with the washers from the Energy Suspension Kit #9.8105 was because the washers that came with the kit I bought, Energy Suspension #8-5118, came from the same company and silly me to think they would have fit.
So, now I can't recommend anyone buy the 9.8105 kit unless they just want the bushings and not the washers.
What a cluster f&*k this whole thing is.
Just received an email from Dominick Luppino who is our technical support specialist at Prothane, who always cared about our problem, but who didn't hear from any users except me and mtbtim for over 5 years, so they simply assumed the parts were the right size.
Good news!
Despite the apologists here who repeatedly argued that 5 mm of ID slop on a 10mm shaft is perfectly normal (for them), the Prothane engineers listened to mtbtim's and my request, read the threads we forwarded to them, and then they did some research on their own, concluding the same thing mtbtim did, which is that all the stock 3rd-generation 4Runners have 26mm say bars and 10mm endlinks.
We're one step further ahead in our goal now!
Finally (after all these years of people repeatedly buying the wrong parts without solving the root problem), Prothane updated their parts kit today!
This is good news, as the main goal was so that nobody else had to go through the amount of effort we did just to get the right sway bar body and endlink bushings for the 3rd-gen 4Runner.
Users might want to wait a while for the current inventory to be used up before ordering the Prothane bushings (letting someone else get the bad ones).
To continually add value so that others find the updated information easier than we did, here's the latest recommended parts kits:
Code:[b]Toyota OEM buna:[/b] (same size for all 3rd-gen 4Runners, 2WD & 4WD) - Toyota 10mm ID Endlink bushings (Part #90948-01003) - Toyota 26mm ID swaybar body bushings (#48815-35100)Code:[b]Daystar polyurethane:[/b] daystarweb.com +1-800-595-7659 tech at daystarweb dot com - Daystar DAY MO3464 Body Bushing ID = 1.045 inches (26.5mm) - Daystar DAY MO2233 End Link Bushing ID = 0.395 inches (10.0mm)Code:[b]Energy Suspension polyurethane:[/b] energysuspension.com +1-888-913-6374 (Dave) dlewis @ energysuspension dot com - Energy Suspension kit 8.5141{R,G}, endlink bushing ID = 9.64mm, swaybar body bushing ID ~= 26mm - [s]Energy Suspension kit 8.5118{R,G}[/s] (Do not buy this kit as the swaybar body bushings are a too-tight fit at over 27 mm) - [s]Energy Suspension 9.8105 kit[/s] (containing correctly sized endlink bushings but incorrectly sized steel washers where the steel washers have to be manually drilled about 20 thousandths of an inch just to be able to go over the 3rd-gen 4Runner 10mm endlinks)Code:[b]Prothane polyurethane:[/b] prothane.com +1-888-776-8426 (Dominick) dominick at prothane dot com - Prothane kit #18-1115 (Be careful to buy only NEW STOCK as the old endlink bushings designed prior to April 19, 2016 are a loose fit at a measured 15.04mm ID on a 10.0 mm shaft)
Thanks @foo and [MENTION=120071]mtbtim[/MENTION] for putting a lot of your energy into this tread!
My sway bar end links look to be original and are toast. I was looking at all the various options and weighing aftermarket vs. trying to put together an OEM parts list. The early portion of this thread had me thinking that the sizes we're off, but now it sounds like that has been corrected.
Anyone have input on what they went with, how they like them, and if they'd go the same route again.
My energy suspension poly bushings are holding up fine. I think I have between 40-50k on them. I did develop some squeaking after some time and re-greased the sway bar and end link bushings when I pulled the sway bar off to drop my transmission pan. So, even though you grease them up really well when you install them, don't be surprised that you have to re-grease at some point.
Can I change the sway bar bushings without disassembling the end links? Just the 2 sway bar brackets? I just had end links done recently w a lot of other stuff.
thx
Well I have to admit doing physical work is getting a little tougher as I age but this is nothing compared to how hard I have to work sometimes as a firefighter with all the gear loading me down and then working super hard at a fire or other emergency scene.
Age is just a number and it definitely helps working out and keeping yourself in shape. I'm hoping to be active my entire life but there's obviously going to be a point where crawling underneath my truck isn't going to sound so appealing when I'm a seriously old codger. I'm one of the oldest people in my fire department now. The jokes about my age keep coming, but it's fun, and I dish it out pretty good too.
Thanks for the compliment. Sean (aka [MENTION=102606]infamousRNR[/MENTION]) gets all the credit for the video work. He's quite the computer geek and knows how to do all that propellerhead stuff that I would struggle with.
[MENTION=762997]alex9000[/MENTION] tool that works for dinged threads comes in handy when needed they last forever.
McMaster-Carr
[MENTION=81614]poleclimber63[/MENTION] [MENTION=120071]mtbtim[/MENTION] turned 66 in Oct. OG old guy original gangster take your pick. :ak472:imp: different lives Lol.
I've wrenched on stuff since about 12 figure it'll stop when I die, like helping others when I can.
McMaster-Carr
