steering wheel cracking
giovannie23
I went off roading over the weekend, on the way back home everything was normal
When I go rinse off my frame about a hour after returning home I took it for a drive ,and the steering had a obvious noise like something rubbing which turned into a clicking noise
It sounds like it's coming from right behind the steering wheel/column area , there's no noise in the front end just the steering wheel
My driving is not affected at all still drives the same but the noise is pretty bad, it happens only when turning the wheel
I took a video, any help appreciated
Thanks!
https://youtu.be/Bj09_3q-VFc
Both do not work I'm gonna replace it.
Are these no good after they been in a front end accident where the airbag deployed?
I've never heard anyone say a deployed airbag damaged a spiral cable. I don't think it would. You never know though.
Happens all the time! Not sure if it applies to third gens, but in general when replacing air bags we replaced the spiral cable too. Sometimes insurance would balk, but usually the mfg recommends it so it was just replaced. Because otherwise you have to do the job again!
thanks for that
the search is on
these things are crazy expensive from toyota
do you guys have a place where you get aftermarket ones?
thanks [MENTION=44978]kball[/MENTION] for mentioning the spiral cable
it was indeed that
i went to pick a part and got 2. there are two different clips for the 3rd gen. i got one for my truck and one from a 99
with the larger clip,
my spiral cable was really bad it barely turns, if anybody wants to see a video i can make one
but im just happy to have my steering back
seltzernator
