Actually you don't have to remove it all, just the shocks which can be disconnected apparently, I still haven't gotten around to removing my oil reservoirs and lines.
The shocks ARE the X-REAS system. There is literally nothing else to it. Springs, c/o hats, etc are all standard stuff. If you remove the shocks though, you remove X-REAS.
Now...you could remove the X-REAS shocks and swap to something standard. Lots of folks do that when X-REAS starts to leak out of warranty (happened on my 4th Gen; tons of posts in that part of the forum). From a lift perspective it really won't get you anything.
EDIT: Nothing else to X-REAS besides the shocks and the oil lines you mention. Just wanted to be clear on that.
The canisters attached to the side of the frame is what I'm talking about in addition to the lines. Basically you can remove the shocks, put in a new suspension without taking the whole system off. Im not saying it would have any function, just that the shocks are all that has to come out.
See here:
http://www.toyota-4runner.org/5th-gen-t4rs/109009-removing-x-reas-limited.html
Also had a recommendation to switch out the 20's for 17's. Why?
Because rubber sidewalls flex. If you want looks and stiff sidewalls for better cornering (i.e., a sports car, or a "mall crawler"), then you go with tall wheels with short sidewalls. This combo has less rubber to flex so it's stiffer.Thanks for the tire info. Any idea what AT tire also gives a good ride and not to "soft" requiring replacement too often?
Thank you for all for the input.
Since there are several wheel manufactures; can you recommend one?
Bought the Limited because I slab it from PA to CA, but always stop in SW Colorado and Moab So before I get myself stuck, what are the capibilities? What would you do as far as mods? Thinking of a Gobi for storage. Not interested in lifting since that would effect MPG. Be kind guys, don't think the Limited would ever be an aggressive rock crawler; am I wrong?
Thanks for your input, and send photos too if you can.
so, with my limited, i can go down to a 17" wheel. im not going to go crazy wheeling but want the look and the capability, if i do a front leveling kit or a "block" style lift then what size tire am i maxing out with?
So you're not interested in lifting it, but you don't want the Limited because it's not enough of a hardcore rockcrawler? :wtf:
Firstly, the Limited is the same basic platform as the Trail and TRD Pro, with full-time 4wd instead of part-time; add a rear locking diff, and you have all the capabilities of the Trail, and potentially more if you consider the Limited's center diff an added advantage, which many do.
Secondly, any 4runner will be good enough, in stock form, to handle 95% of the roads you will ever encounter in North America. If you really want to be able to tackle that last 5%, you'll be looking at adding a lift, bigger tires, potentially a front locker (though ATRAC may allow you to muscle through most terrain), ect. The only major difference between the "hardcore" models like the Trail and TRD and the rest is that the former have a rear locking diff, which gives you a head-start in the modding game.
All that being said, if you want something that can occasionally get you over rough terrain but will probably spend 99% of its time on pavement or gravel roads, a SR5 or Limited would be more than enough. 4wd low, or 4wd with center diff locked for the Limited, combined with smart driving will get you over most obstacles. I have a trail and I've only had to use the locking rear diff 6x: 4x because I purposely went through some terrain that required it (there were bypasses) and 2x because I actually needed to get unstuck or out of rough terrain.
The locking rear diff, while a potent tool, is akin to a fire axe you sometimes see in the emergency fire stations in hallways: you rarely have a need to use it, and if you do, its because you don't have any other options.
