Stormtrooper 2.oh
Desert36
Got the build done on the new rig, fairly textbook besides my choice of tires(measure out to a true 33"s), only other customization I had to do was the front mud flaps needed to be strapped tight to clear the tires while turning/articulating. The hardest part of the lift kit was the rear springs and re-attaching the kdss swaybars(I did the strap the cylinder method, no ill effects or bleeding of the system yet(500mi)).
Front wheel turned ^ it was rubbing before
Vs. stock +tint
Needs some Imperial badging!
Like this? :)
20160317_163839_zpsjzgk7e9u.jpg~original
20160121_065608_zpszc04qhst.jpg~original
Can you explain what you did to the front mud flap to strap it in tight? Oh and those are some sweet tires!
Drilled a tiny hole near the middle lip and used bailing wire to the body mount, it was meant to be a temporary fix till I can get the time to make some bracketry for it but it seems to be doing good
044runner4
