Strange temp and heater behavior after thermostat replacement
giro
I took my 4runner out for a test drive this morning, after fixing several things post-fan explosion. I went ahead and replaced the thermostat yesterday, since the fan had sliced the coolant return line and I needed to add coolant. After replacement I filled up the fluid in the radiator, and put some in the antifreeze overflow thingy.
But it was then dark, so I didn't run the truck.
Today my test run was to head to our soon to be rental, which is up 800 feet from our house over 3 miles or so. I don't have a fan, but with temps at 35° or so, I wasn't too worried. I took it easy, and watched the temp gauge. Strangely, it stayed off the low end for quite a bit, over a mile. Then it jumped up to 50%, and kept climbing. At 75% I pulled over. I also turned on the heater, and it just blew cold air.
After a minute I headed down the hill, using brakes instead of the engine to keep is slow. The heater blew cold air until just before getting home.
What I'm thinking is that there was a big air bubble that was back by the water temp sensor, and also either in the heater core or whatever decides if the heater core should get heat. When the temp on the gauge changed so much, that was the water temp sensor getting coolant. And then the heater didn't start blowing hot until the heater core was given some hot coolant. It might have pulled in the extra antifreeze then, though the FSM makes it sound like that normally only happens when off and cooling.
Does that make sense? A smaller, shorter, flatter test run 3 hours later seemed fine. I'm thinking things are fine now. But I wanted to get ideas if there was something wrong. I was worried the fan might have sliced the temp sensor wires, but it looks like that's back behind the engine.
Yep, afterwards it was just slightly low, but had slurped up all that was in the reservoir too. Between what I added then and what had been in the reservoir, it was probably a quart.
To me that seems to explain it.
I just took it out for 15 minutes driving up some hills, and it never got above 50% on the temp scale. It's normally more like 35-40% when the fan is in, so this is decent.
I might take it up to the top of the mountain in the morning if we get some snow. That would be 2200' in maybe 8 miles. If it can stay steady for that, I'll be feeling fine….though I should be getting my fan blade and power steering return line tomorrow too.
Almost definitely air in the lines. When you're filling the radiator, park on a steep slope or jack the front of the truck up, then let it run until the engine hits operating temp and start blasting the heater. That frequently will purge the air and you can top the rad off without having to drive it first.
Freddygino324
