StreetKill831
Went to do the "bump-the-starter" method earlier today and the battery died the second I turned the key.. I guess that's what you get when you have a ****ty battery that doesn't get charge because the engine doesn't run lol.
Anyways so until I charge up the battery this is how the engine sits:
After running into this problem I decided to start pulling panels and getting at the e-locker wiring. From what I can see it looks like it is going to be a bit more difficult than I was expecting because so much of the wiring is intermingled with all the other wiring, especially near the ECU.
Also, I am having trouble figuring out where the wiring for the button goes because it seems to just go up past the cross bar and I can't follow it.
I am also frustrated by the fact that I found two different wires that are attached to nothing.
This one seems to be a ground wire for something:
and this one is attached to what looks to be part of the steering column:
I'll probably just check out my '98 and see where those should be and figure out exactly what is needed in the wiring harness swap.
Fun, fun, fun..
Fun, fun, fun..
