Stripped out the rear bump stop nut, anyone have a MOD for this?
While installing the rear bump stops, the welded nut on the rear hanger just came apart. Has this happened to anyone here? Can I just air hammer the nut off and just replace with another nut? Any suggestions? Also, I destroyed the factory rubber bump stop, can't fine a new one. Who makes a good one to stick on the end of my Toy-Tec extenders?
Air hammer it off clean. Go to junk yard and find any 00ish blazers and get the bump stops off them and take the bolt also install and done. Fine a good one that is not rotten or weathered. Problem solved for around 15 bucks.
Good luck finding a blazer in Huntsville that doesn't have rotted bushings or rusted mounts. I tried. I'd go on Amazon and buy a set of Daystar competition bump stops in the length you want. They should bolt through the Toytec spacer thing and then just put a nut on the other end.
EDIT: I can't guarantee that the Daystar bump stop stud will fit through the hole in the Toyotec spacer, but I'm sure you can do a little research and figure it out.
I agree with above post. Not a blazer bump stop fan, but that seems to be just me. https://www.google.com/webhp?source...F-8#q=daystar+competition+bump+stops&tbm=shop
Research and fine one with the correct specs and center stud mount.
tuckd
