Stuck crank pulley bolt.... WHY?!?!?!
fo' runnin'
Trying to put a new timing belt on my '93 3vze and I can NOT get the crank pulley bolt out for ANYTHING... used a 4' cheater bar and also a 500ft. lb. impact @ 125psi and it wouldn't budge.... any ideas on what else I could do?!
put the breaker bar on it, and rest it against the steering box or frame, disconnect the coil, and bump the starter over.
You need a pulley holder, along with pipe extensions , it will roll right out. Using the starter and ring gear for removal, will only lead to damage. It doe take some strength upon removal of the collar(crank) bolt. I almost broke my pulley holder tool(OTC or the like) during the last t-belt job. Best of luck with it.
regards
peacefulpiranha
