Sunroof UV Protection
There is some discussion on whether adding window tint is ok for sunroofs. Maybe ask your local shop if Ceramic Tint would work for the sunroof?
Are you sitting in one spot with the sunroof open? Or on a cross country trip on a road that just happens to give you many hours of direct exposure via the sunroof? I am trying to think of a situation where you would get the most amount of direct sun via the sunroof more so than the windows themselves.
Folks, I wasn't looking for sage advice. Surprisingly, Im smart enough to figure out the obvious. I just wanted to see if anyone had the specific UV rating of the glass piece so I can determine if additional tint is needed. I'm planning to add tint now, so you can carry on with the shenanigans.
I want the sunlight but I need shade. :suspicious:
Wear sunscreen.
Have you ever tried getting sufficient sunscreen on your scalp when you have hair?
Read above... this question was for the sunroof being closed. The front windows already have tint with a high UV rating.
He enjoys being contrary from time to time.
Just check with a good tint shop and seek their best solution.
Does anyone know how much UV protection the oem sunroof glass has?
Glass naturally inhibits some types of UV transmission, but the effect on UVA and UVB depends on the type of glass. If you're worried, I'd do some research and apply a specific material that you think will reduce transmission near to 0%. Maybe here is a good start?
https://www.ncbi.nlm.nih.gov/pubmed/19614895
https://www.ncbi.nlm.nih.gov/pubmed/23593780
https://www.ncbi.nlm.nih.gov/pubmed/16635665
The third seems most useful, full text should be available here: http://www.jaad.org/article/S0190-9622(05)04624-4/fulltext
Thanks. Ill see if i can see any kind of markings that may help classify it.
I would assume it's the same unlaminated glass that comes in side windows. Tint may make a substantial difference, but I don't know. I'm sure you could get a glass company to replace it with tinted, laminated glass, but not sure if that affects the sunroof system (motors rated for specific weight?, etc?) or whether it's practical to replace this glass.
Eh, can just tint it for now. Llumar and 3M have have high VLT tint with 99%+ UV protection.
I had Ceramic Tint put on mine.
I think I told them to put the next darker shade than clear.
Knocks out the UV's and the heat.
"Let the Sunshine In" :hello:
patnewton
